Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Unread 23-01-2016, 09:47
SupremeSteak1 SupremeSteak1 is offline
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
SupremeSteak1 is an unknown quantity at this point
GRIP deploy: bash: /bin/java: No such file or directory
The title pretty much states the problem. When we try and deploy a GRIP program to the roborio, we get the error: bash: /bin/java: No such file or directory, and the loading bar says "Running GRIP" We cannot seem to find a solution to this problem, or anyone else who has had it. Any help is appreciated! Thanks!
Unread 23-01-2016, 09:56
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: GRIP deploy: bash: /bin/java: No such file or directory
You have to install Java on the RoboRIO
http://wpilib.screenstepslive.com/s/...ller-java-only
Unread 23-01-2016, 10:08
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
We have followed the screen steps tutorial previously, and I just did it again to be sure, but it still is not working. Thanks for your quick response!
Unread 23-01-2016, 10:32
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Well that is exactly what the error is saying... Does that folder / files in the folder exist if you connect to them via filezilla?
Unread 23-01-2016, 10:41
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
Bin exists, java does not. Is there another way we could try to install java instead of the screen steps way?
Unread 23-01-2016, 11:14
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
I'm pretty sure all the installer does is ssh over the linux installer for Java then runs it... you could try doing that manually. Just be sure to get the right distro that it tells you to get in screensteps
Unread 25-01-2016, 14:33
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Go to your project settings and make sure Deploy Java Home is set to "/usr/local/frc/JRE". It should be by default, but it could have gotten changed
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
