Go to Post So we dont need a brain to run the minibot? - TheGuyz [more]
Unread 01-23-2016, 10:08 AM
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: WCP MCC Robot 2016 powered by VEXpro!
Originally Posted by Justin Montois View Post
It's also worth mentioning that most of the "extending outside the 15" perimeter" Issues will be dealt with during inspection. The only time I've ever seen it called on the field in prior years is when a robot is "flailing" something obviously outside the frame. These +/- a few inches calls during scaling won't be made by the referee crew because it's not realistic for them to see when a robot is 16" outside of it's frame for a split second during a fast climb.
This is why I expected a change to G18 during scaling. Every one said it's supposed to be hard and things like that but for me it came down to can it be called easily be the referee and/or checked during inspection. The answer to both of these questions is no. And rules you cannot enforce should not be rules.
That doesn't mean you should knowingly break the rule and hide it in inspection. I've seen teams do this in the past and got a hint of that from your post. Teams should never look at this as a viable solution to play the game.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
