Re: can the 2015 dlink be reprogrammed for 2016
thanks for the reply. i was already aware of the requirement for the new radio at the competition. we want to use the dlink on our practice robot (not the one we use in competition) and was wondering if it can be reprogrammed to work with the 2016 software update. right now we have it programmed for last year's competition and it does not work with a roborio that has been updated to 1016 software.
so my question still stands, can the dlink be reprogrammed to work with the 2016 software? |
The 2016 FRC Radio Configuration tool has a setting to program the older DLink for use with this year's robot.
Follow the directions in programming radio for home use in screensteps. |
Yes. The old Dlink works with the new 2016 environment. We are using just that for our software development platform.
For home/shop use only, can you not just use any router that can provide DHCP to your RoboRio and your driver station laptop?
#7
Yes, you can use any router you want to at home.
It's just a router/AP, nothing special. You don't even have to change the router IP to a 0. address, it's just usually convenient to do so. DHCP serving 10.te.am.20 and higher addresses (or similar) is all that's necessary. I use all my old outdated home AP/router/DSL/whatever to run old robots. Last edited by Mark McLeod : 25-01-2016 at 12:47. |
#8
What happened to Team 358's website?
We had bookmarked lots of good info, back during Fall 2016; and, then every time we wanted to refer to some info on your website for the past 6 weeks it was gone....the whole site, in fact. Thanks, - Rob |
#9
About 2 weeks into build season our hosting service couldn't handle it any longer, so we are switching to a new service.
But with how busy build season is I just haven't had time to redirect the nameservers. It'll get done soon, after I've had a bit of a rest. The site is mostly available via the Wayback Machine Last edited by Mark McLeod : 24-02-2016 at 08:41. |
