Go to Post Blasphemy! This is FRC we must over analyze everything! - Ginger Power [more]
Unread 23-01-2016, 12:47
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
NavXUI Error 126
We are using NavX for the first time. We managed to flash the latest firmware, and calibrate it, including the magnetometer.
However, when I try to launch navXUI, I get the error:
LoadLibrary failed with error 126: The specified module could not be found
I tried reinstalling the software, and same error. We are using Windows 7
Any thoughts?
Unread 23-01-2016, 13:25
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: NavXUI Error 126
Any thoughts?
Sounds like all of the PC-side software works except for navX-UI. The navX-UI has problems on some systems when it is running 32-bit Java. The first thing I'd recommend checking is what version of java you have installed on your system.
Java 7 (version 1.7) or Java 8 (version 1.8) are required, the 64-bit version of Java is recommended and in some cases we find it is required. To tell which version of java is currently "Active", open up a command window, and type this command:
java -version
So please run that check and if you find the version of java is not 7 or 8 and is not 64-bit, please update your system.
If you have a 32-bit operating system, check that you have 32-bit java installed.
