Go to Post I've had parents tell me I'm a great role model for their daughters, because I was a female leader. It's a great feeling to hear something like that. - Liz Smith [more]
Unread 23-01-2016, 11:05
marshmello marshmello is offline
FRC #1711 (The Raptors)
Rookie Year: 2015
marshmello is an unknown quantity at this point
Alternatives to churros?
Due to the design of our robot this year, we're worried about the frame of the robot twisting while driving. We had the same concerns last year, so we added churros across the frame to stabilize it.
This year, churros have raised some concerns because of availability and added weight. Does anyone have any good alternatives to churros for cross-bracing?
Unread 23-01-2016, 11:10
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Alternatives to churros?
The best option is a solid belly pan. Some hardwood plywood or 1/4" polycarbonate works wonderfully. If you can manage a sheet of material on the top and bottom, that works even better.
Unread 23-01-2016, 11:39
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We are just using 2x1 versaframe in place of churros.
Unread 23-01-2016, 13:02
You could always try all-thread with a couple sets of washers and nuts on each end.
Unread 23-01-2016, 14:39
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Cut and notch an addition End Plate? (AM-2953a)
Unread 23-01-2016, 14:49
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 23-01-2016, 14:55
REVving up for a new season
FRC #2848 (All-sparks)
You can use the 1inch REV extrusion for this also. The reason we have 5 holes in the end is so you can put multiple screws in to prevent twisting in the mounts.
You can see an example of this with the Rhino Tank drive where they are integrated.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 23-01-2016, 14:59
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
This is what my team is doing, although we may also add the existing churros in for more support.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 23-01-2016, 17:52
philso philso is offline
FRC #2587
Beignets would be a great alternative too!
Unread 23-01-2016, 20:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Yeah, you right!
Back to OP: We are putting some lengths of heavy versaframe under the chassis, just either side of the gearbox. We will use these and a slightly angled skid plate to provide protection and hold the plates apart. We aren't that much worried about minor twisting of the frame; I understand that more flexible frames are actually doing better crossing the defenses.
We aren't worried too much about making weight this year. Once we decided to be short enough to get under the low bar (though not in the original configuration) and high enough off the floor to get over the defenses, there is a rather limited space to work with. We're only planning three actuators other than the drive system: intake, raise/lower intake, and launch. Climbing is not out of the question, but below the line on our priority list. We're more worried about keeping our CoG as low as possible.
