Go to Post Bless you sire and all your HD camera goodness. - pyroslev [more]
Unread 23-01-2016, 14:11
Pyro_84 Pyro_84 is offline
FRC #1769
Pyro_84 is an unknown quantity at this point
Compressor not starting
I've opened the solenoids in my Begin.vi, and have corresponding programming in the teleop.vi. The solenoids respond, but my compressor isn't starting. I'm not sure if this is entirely programming or if it could be the PCM. We've switched out the New PCM from this year with the old one from last year. And nothing has happened.
Any Suggestions, or help?
Unread 23-01-2016, 14:16
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Compressor not starting
Check out section 4.1 in PCM users guide.
http://www.ctr-electronics.com/pcm.h...ical_resources
Unread 23-01-2016, 18:10
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Try shorting the leads of the switch. If the compressor turns on, then the switch is bad.
Unread 24-01-2016, 08:54
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Since there is no robot code needed to run the compressor, this is almost always a wiring issue.
Unread 24-01-2016, 17:09
There's no explict code required, assuming that you've opened a solenoid. This isn't the OP's issue, but is important to remember in other cases.
Unread 25-01-2016, 09:40
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
You might take a look at the Solenoid With Compressor example that ships with LabVIEW. It shows how to wire the hardware. From within LabVIEW go to Help>>Find Examples... to launch the Example Finder.
Doug Norman
