Go to Post I think one of they beauties of the program is how it can include so many different interests our students have. - Doc Wu [more]
Go Back   Chief Delphi > Technical > CAD
Unread 23-01-2016, 14:14
Heburn's Avatar
Heburn Heburn is offline
Computer Jockey
AKA: Espen Storfjell
FRC #2557 (SOTAbots)
Team Role: CAD
Heburn is an unknown quantity at this point
BXD Synthesis problems
So, I've been tasked to get this years field up and running in BXD Synthesis, a robot simulator program from Autodesk. I'm having trouble configuring the field for export, and I was wondering if anyone has already set it up.
"Can I get an 'Oh Yupp?'"
Unread 23-01-2016, 19:41
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: BXD Synthesis problems
I will try to import the field over the weekend and get back to you.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 24-01-2016, 16:54
Heburn's Avatar
Computer Jockey
Team Role: CAD
Thank you so much!
Unread 27-01-2016, 15:50
I have been playing with the BXD application and have not run into any problems with exporting simple parts. Since you can only export parts, not assemblies, there is a fair amount of work to be done converting subassemblies to parts. The tutorial walks you through how to do this.
Here is what I suggest to get started.
1. Identify a subassembly from the field assembly. For example the floor.
2. Convert it to a part as per the tutorial instructions.
file:///C:/Users/phill/AppData/Local/Microsoft/Windows/INetCache/IE/9Q4RONP0/fieldex.pdf
3, Use the export work flow as per the instructions.
Let me know if this simple example works for you.
Phil Dollan
Autodesk Inc.
