Go to Post I include these trivial facts for the sole purpose of confusing people. :p - KarenH [more]
Unread 23-01-2016, 12:36
homerun33ss's Avatar
homerun33ss homerun33ss is offline
AKA: James
FRC #3238 (Cyborg Ferrets)
Team Role: Electrical
homerun33ss is an unknown quantity at this point
Talon SRX Stacking?
Is it okay to physically stack Talon SRX controllers on top of each other to save space in our electronics board setup? I know the previous Talons were stackable if you used spacers to separate them enough, which still allowed them to release heat through the top. Can you do the same thing to Talon SRX's, and if so, do you need to make your own custom spacers, or are there specific spacers available for purchase?
Unread 23-01-2016, 13:18
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Based on the way the heat fins work you don't want them directly on top of each other. I would personally want at least a 1/4" spacing between them vertically. For that a 3d printed bracket would probably be your best bet.
Unread 23-01-2016, 13:29
AKA: James
Re: Talon SRX Stacking?
Yeah, that's what we were suspecting, but we just wanted some extra input. Thanks!
Unread 23-01-2016, 13:33
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I think it depends on the application. If it's not super current-heavy then you can get away with it.
Last year we used all talon SRXs for stacking and drivetrain, and they never got more than warm. We stacked quite quickly too.
Unread 23-01-2016, 13:56
AKA: James
When I said stacking, I meant physically stacking the TalonSRX's on top of each other to save space in our electronics board setup. Sorry, I should probably clarify that in the OP.
Unread 23-01-2016, 14:36
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I knew that would be a problem when I typed it. My bad.
We did not stack up our Talons, but used them for current-heavy stacking of totes. Knowing that, I would be comfortable stacking SRXs right on top of each other like you describe for non-heavy applications.
Unread 23-01-2016, 17:34
philso philso is offline
FRC #2587
You can probably get away with it if the current draw is low (you are controlling a bunch of AndyMark 9015's) or if the current draw is high but has a short duration with a long cool down time (eg. 0.5 seconds at 35 A then 5 seconds off). You should test in a prototype as you would use it in competition or practice then quickly check the temperature of the metal casing of each and every Talon SRX. If you can hold your finger on the case, it is generally Okay. You may want to stack them side by side rather than on top of each other so that you can see the two status LED's and access the Cal button.
I did not notice any mention in the Talon SRX User Guide of being able to read the temperature of each controller. If it is possible, that would be a good thing to monitor in your software.
Unread 25-01-2016, 10:22
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
CANTalon.getTemperature() is in there.
Unread 25-01-2016, 10:23
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
"It's Talons all the way down!"
Unread 25-01-2016, 10:36
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I would suspect that, as someone above has said, you would like to be able to see the LEDs and press the calibrate/brake buttons.
Maybe mount the Talons side by side on a plate that you could then mount vertically?
