Go to Post Al's Murphy's law corollary...If it can go wrong, it will on Einstein - Al Skierkiewicz [more]
Unread 23-01-2016, 15:15
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Print to Driver Station?
With the roborio, processor usage on a simple print shouldn't be an issue.
You could also use networktables and print to the smartdashboard
Unread 23-01-2016, 15:21
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
You'd be surprised (though I shall say nothing as I aim not to provide un-researched claims of the Driver Station and the roboRIO)
have you tried DriverStation.reportError?
Unread 25-01-2016, 18:17
NegativeZero NegativeZero is offline
FRC #3098
NegativeZero is an unknown quantity at this point
I have tried that, but i am being thrown a lot of warnings/errors.
CTRE CAN Recieve Timeout at edu.wpi.first.wpilibj.hal.CanTalonJNI.GetAppliedThrottle(Native Method)
edu.wpi.first.wpilibj.CANTalon.get(CANTalon.java:577)
edu.wpi.first.wpilibj.CANSpeedController.updateTable(CANSpeedController.java:159)
edu.wpi.first.wpilibj.CANTalon.updateTable(CANTalon.java:1773)
edu.wpi.first.wpilibj.CANTalon.initTable(CANTalon.java:1765)
edu.wpi.first.wpilibj.livewindow.LiveWindow.initializeLiveWindowComponents(LiveWindow.java:86)
edu.wpi.first.wpilibj.livewindow.LiveWindow.setEnabled(LiveWindow.java:108)
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:101)
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)
My code is
String DSPrint;
protected void execute () {
if (Robot.oi.driver.getRawButton(8) == 1)
DSPrint = Button On;
DriverStation.reportError(DSPrint, false);
else
DSPrint = Button Off;
Any ideas?
