Go to Post ...the great teams in FRC will probably continue to be great teams. That is because they have great people who embrace the challenge rather than whine about it. - dtengineering [more]
Unread 23-01-2016, 14:17
NegativeZero NegativeZero is offline
FRC #3098
NegativeZero is an unknown quantity at this point
Print to Driver Station?
Hello,
I am looking for a way to display messages in the driver station using a function other than println()'s, as i am afraid that this may result in too much processor usage on the roborio. I am aware of the DriverStationLCD class, but that appears to have been removed from the latest version of WPILib. (http://wpilib.screenstepslive.com/s/...rrors-warnings)
Thank you in advance!
Unread 23-01-2016, 15:15
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Print to Driver Station?
With the roborio, processor usage on a simple print shouldn't be an issue.
You could also use networktables and print to the smartdashboard
Unread 23-01-2016, 15:21
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
You'd be surprised (though I shall say nothing as I aim not to provide un-researched claims of the Driver Station and the roboRIO)
have you tried DriverStation.reportError?
Unread 25-01-2016, 18:17
FRC #3098
I have tried that, but i am being thrown a lot of warnings/errors.
CTRE CAN Recieve Timeout at edu.wpi.first.wpilibj.hal.CanTalonJNI.GetAppliedThrottle(Native Method)
edu.wpi.first.wpilibj.CANTalon.get(CANTalon.java:577)
edu.wpi.first.wpilibj.CANSpeedController.updateTable(CANSpeedController.java:159)
edu.wpi.first.wpilibj.CANTalon.updateTable(CANTalon.java:1773)
edu.wpi.first.wpilibj.CANTalon.initTable(CANTalon.java:1765)
edu.wpi.first.wpilibj.livewindow.LiveWindow.initializeLiveWindowComponents(LiveWindow.java:86)
edu.wpi.first.wpilibj.livewindow.LiveWindow.setEnabled(LiveWindow.java:108)
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:101)
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)
My code is
String DSPrint;
protected void execute () {
if (Robot.oi.driver.getRawButton(8) == 1)
DSPrint = Button On;
DriverStation.reportError(DSPrint, false);
else
DSPrint = Button Off;
Any ideas?
