Go to Post Copies gonna copy. - Arpan [more]
Unread 23-01-2016, 15:21
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Print to Driver Station?
Originally Posted by euhlmann View Post
With the roborio, processor usage on a simple print shouldn't be an issue.
You could also use networktables and print to the smartdashboard
You'd be surprised (though I shall say nothing as I aim not to provide un-researched claims of the Driver Station and the roboRIO)
have you tried DriverStation.reportError?
Unread 25-01-2016, 18:17
NegativeZero NegativeZero is offline
FRC #3098
NegativeZero is an unknown quantity at this point
I have tried that, but i am being thrown a lot of warnings/errors.
CTRE CAN Recieve Timeout at edu.wpi.first.wpilibj.hal.CanTalonJNI.GetAppliedThrottle(Native Method)
edu.wpi.first.wpilibj.CANTalon.get(CANTalon.java:577)
edu.wpi.first.wpilibj.CANSpeedController.updateTable(CANSpeedController.java:159)
edu.wpi.first.wpilibj.CANTalon.updateTable(CANTalon.java:1773)
edu.wpi.first.wpilibj.CANTalon.initTable(CANTalon.java:1765)
edu.wpi.first.wpilibj.livewindow.LiveWindow.initializeLiveWindowComponents(LiveWindow.java:86)
edu.wpi.first.wpilibj.livewindow.LiveWindow.setEnabled(LiveWindow.java:108)
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:101)
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)
My code is
String DSPrint;
protected void execute () {
if (Robot.oi.driver.getRawButton(8) == 1)
DSPrint = Button On;
DriverStation.reportError(DSPrint, false);
else
DSPrint = Button Off;
Any ideas?
