Go to Post FIRST is not about building robots, it is about building people; the robots are just a good way to get the people there. - JamesBrown [more]
Unread 23-01-2016, 13:47
Drew_trak's Avatar
Drew_trak Drew_trak is offline
AKA: Drew Petrak
FRC #0599 (Robodox)
Drew_trak is an unknown quantity at this point
Vandoor motor sprocket HELP
Hey guys!
So my team was planning on using the Van Door motors this build season; however, the output shaft is some really awkward size (maybe metric ). We were just wondering if anyone used those motors before and could help us determine which sprocket to use on the output shaft and where we could buy the sprocket from.
THANKS!
TEAM 599
Unread 23-01-2016, 15:57
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: Vandoor motor sprocket HELP
Is there a part number on these? Van they came out of?
A micrometer reading of the outside tooth diameter, and number of teeth would help. Try to measure root diameter as well. Shaft Diameter ?
Hard to help without some specifics.
Might be possible to replace the output gear with a FRC standard 20DP gear.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
