Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 23-01-2016, 15:00
J-Chillin J-Chillin is offline
FRC #0910
J-Chillin is an unknown quantity at this point
3-way PWM Splitter
Hey so our team has found a way to run 3 motors on our drive train to one PWM signal. Does anyone know where we can find a 3-way PWM splitter? All the ones we've been finding are 3-way but don't have the right connectors. Thanks!
Unread 23-01-2016, 15:55
Re: 3-way PWM Splitter
You could always use two two-way splitters. Attach one to one leg of the other, bundle the excess, and you have a three-way splitter.
Unread 23-01-2016, 16:08
REVving up for a new season
FRC #2848 (All-sparks)
I would make your own by soldering multiple cables together.
We (REV) provided a bag with 8 PWM cables, 2 Y cables, and a 2 wire jumper this year. If you cut the heat shrink tubing off of the Y cables it should be easy to solder in an extra lead from one of the PWM cables cut down. Remember that you don't need to solder the red wire at all as it is not connected to anything in your motor controller anyway.
All that being said, are you using so many motors that your roboRIO has no free ports? As an alternative, you could wire each motor controller individually to the RIO (and if you run out of ports you could use the extra ones broken out from the MXP connector.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 23-01-2016, 16:31
In case someone wants to try this with the older motor controllers: does anyone know if a single roboRIO PWM output can reliably source enough current to drive 3 of the older low-input-impedance controllers ?
Unread 23-01-2016, 19:16
philso philso is offline
FRC #2587
Avoid mixing makes AND models of motor controllers. Most of the ones I have looked at use a photocoupler as the input device. The different models, even if they came from the same manufacturer are likely to use different photocouplers. Different photocouplers will likely have different Forward Voltages, VF. If you put different controllers, with different VF's, only the one with the lowest VF will work.
Unread 23-01-2016, 23:08
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
nandeeka is on a distinguished road
Is this even legal given R53?
R53 Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device shall control one and only one electrical load.
Unread 23-01-2016, 23:21
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
R53 applies to the Motor Controller, not the PWM signal that controls the Motor Controller.
If you are running out of PWM ports, you might want to consider CANbus to control the motor controllers.
Unread 25-01-2016, 08:02
philso,
None of the controllers that I have looked at have a raw opto-coupler input connected to the PWM port. There should be a series current limiting resistor so the V forward difference should not show up as a problem. That being said, single point of failure is likely to raise it's ugly head if one is not careful. A bad controller will take down all three, a pinched wire will take down all three. Your mileage will vary.
Unread 25-01-2016, 08:36
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I want more of your 2-wire jumpers!!!! They are very nice quality.
You please to make nice special price for me on world wide web? (I looked and could not find them on the REV site, are they available to purchase?)
Unread 25-01-2016, 09:46
FRC #2587
philso,
We confirmed with the manufacturer that we should not have been paralleling the inputs of the two types of motor controllers we had and that the LED VF's were the problem. Once we had only controllers of one type connected together, they all worked properly. We had no defective motor controllers.
Perhaps some of the motor controllers have a current limiting resistor in series with the LED. If the one with the lowest VF does not have a current limiting resistor, it will still prevent the other ones from turning on.
Unread 25-01-2016, 09:56
The SPARK has a 150 ohm series resistor with the optocoupler's LED. If you are curious about anything else inside the spark our complete schematic is in the back of our users guide on our website. http://www.revrobotics.com/wp-conten...1200-UM-00.pdf
Unread 25-01-2016, 10:17
We decided not to sell these (or any of our cables) this year as we couldn't offer a significant savings over what teams already are buying or are available other places online.
Send me a PM, I might have some lying around I could send you if you let me know what you need.
Unread 25-01-2016, 16:08
Carter1671 Carter1671 is offline
FRC #1671 (Buchanan Bird Brains)
Carter1671 is an unknown quantity at this point
Hey! PWM does not supply the power to the motors, just tells the motor controllers when and how to run the motors. So, a single PWM output from a roboRio to three motor controllers should be okay.
Unread 25-01-2016, 16:15
Hi Carter. Welcome to Chief Delphi.
Check out this thread. It will give you the necessary background for the question:
http://www.chiefdelphi.com/forums/sh...01&postcount=5
Unread 25-01-2016, 17:06
Data Nerd
FRC #0079
I don't know about the RoboRIO, but my AR400 RX is capable of driving 4x of the old style Talons while being powered off the 5V rail on a PDB and it's not exactly a high end piece of kit (I think it was the cheapest 4 channel RX my local store had) [1] Unless you mean old 884/883 style Victors in which case, I'd have to wire something up.
[1] mechanical folks wanted all motors tied to one stick. I could either put a full control system on the bot or cheat and use the RX/TX system I had sitting around for other things. I'm lazy.
