Go to Post The students who benefit from FIRST are the real "trophies". - David Brinza [more]
Unread 23-01-2016, 16:44
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
High Coefficient of Friction Rubber Wheels
We are currently using the 8" 2010 FIRST wheels for a flywheel shooter, but if we turn the wheels at a high speed, the ball slips due to the low coefficient of friction of the wheels. Is there an alternative 8" wheel we can use, which has a higher coefficient of friction, and doesn't shred the balls (the KOP chassis wheels shred the ball for sure)?
Unread 23-01-2016, 17:17
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Re: High Coefficient of Friction Rubber Wheels
Most flywheel shooters use compression to increase the normal force, which causes the friction to increase. The wheels you are using should work for your shooter, however you will need to adjust the geometry to compress the ball a proper amount to allow for accurate and consistent shooting.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 23-01-2016, 17:28
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I wouldn't worry about any wheels in particular spreading balls because the all will eventually. We have the 4" wheels on our shooter. And Ri3D greenhorns used them.
Just remember compression is everything.
Unread 23-01-2016, 17:46
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is an unknown quantity at this point
Just move the wheels closer together, the compression on the ball will solve your problem.
Unread 23-01-2016, 18:24
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
68 used those exact wheels in 2012 with great results, and those balls were as slick as or slicker than the balls this year. As others have said, compression is everything. We had a maximum of about 2.5", and I don't suspect that teams will need any more than that to shoot from the outer works this year. It's possible, but with a reasonable speed I think it should be enough.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
