Go to Post Yes indeed... ten years ago tomorrow, those famous words "water game" were first mentioned on Chief Delphi! Oh, how things have and have not changed... - bduddy [more]
Unread 23-01-2016, 18:09
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
775 Pro Coupling
Has anyone come across a 3mm press fit coupling for the 775 Pro?
I am trying to adapt the motor in a high RPM application directly to a pulley.
The GT2 pulley that WCP offers has a large cantilever due to the fact that the 775 pro has such a short output shaft. I would like to find a coupling that does not use a set screw (in fear of it coming loose) to a direct drive a gt2 or like pulley. If anyone knows of something that gets you from the motor too 1/4" or 3/8" diameter shaft and can be used in a high RPM application please let me know.
Thank You
Unread 23-01-2016, 18:11
Re: 775 Pro Coupling
Sure you can't use a 1:1 VersaPlanetary?
Unread 23-01-2016, 18:15
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Yea... I would use a versaplanetary 1:1 or even 3:1 these guys are faster then you think.
IMO directly mounting to those shafts is a bad idea.
Unread 23-01-2016, 18:16
kbrowncny's Avatar
AKA: Kevin Brown
The versa planetary would definitely work, however you must use a set screw to install it. I may be over-cautious, but I am fearing set screws this year because of the nature of this game and I don't want anything to come loose, especially in a high RPM application such as a shooter wheel.
Unread 23-01-2016, 18:20
Sperkowsky's Avatar
We used a set screw+A shaft key. It doesnt directly key the motor shaft but it does help. You could also cut a small slot in the axle with a dremmel, or lathe and connect it to the adapter with a DIY shaft key. The adapter has a gap so its not an issue.
Unread 23-01-2016, 18:23
Chris is me's Avatar
AKA: Pinecone
Think about it this way. No matter what gearing the output of a VP is spinning at, the input will be spinning at the free speed of a motor. If that coupling has held on at high speeds to motors for years, why would it fail now? I'm not saying set screws in general are the best idea, but the VP design is tried and true. The VP will also provide a much better supported output shaft than you would have otherwise.
This is a horrible idea. How do you cut a slot in a 3mm wide shaft? How big would the slot even be? Maybe 1mm?
Unread 23-01-2016, 18:27
kbrowncny's Avatar
AKA: Kevin Brown
Looking to do something like this.
Unread 23-01-2016, 18:29
kbrowncny's Avatar
AKA: Kevin Brown
https://picasaweb.google.com/1158296...24994519130514
Unread 23-01-2016, 18:40
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
If your looking to do that, then its the same as buying the GT2 pulley here:
http://www.wcproducts.net/gt2-timing-pulleys-belts
R.C.
MadTown Robotics Team 1323
Unread 23-01-2016, 18:51
kbrowncny's Avatar
AKA: Kevin Brown
What are the recommended installation instructions (ie spacing from motor) for the WCP pulley?
I am interested to see it installed and running, I have a fear about the cantilever off of the motor output shaft because there is so little engagement. There is very little info about it on the website.
Unread 23-01-2016, 19:50
R.C.'s Avatar
Your not going to run into an issue with shaft stick out, it is the same as the Banebot 775. 254 & 971 run the 12T pulley on their stuff, you can check out CAD from FRC971 on their site.
You can also email support@wcproducts.net for more info/concerns.
R.C.
Unread 23-01-2016, 21:31
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We were also concerned that 775 motors might not handle side loads well.
We've had good results using 3/8 hex shaft stock (217-3310) to fabricate 5mm bore press-fit shaft adapters for the 775pro. Here is our method: (lathe)
-- rough cut stock ~1 inch long using chop saw or band saw
-- face both ends to give 7/8 inch finished length and break edges
-- center drill
-- drill through #21 (0.159 inch dia)
-- drill about halfway through #9 (0.196 inch dia) <-- this step gives a press fit hole diameter for the 5 mm motor shaft
-- tap the smaller end 10-32
-- using arbor press, align squarely and press motor into large end of adapter
(Note: arbor press ram should only touch the back shaft, not the motor body)
A 3/8" hex bore gear on the adapted motor shaft drives a larger gear on a 1/2" hex output shaft. Both shafts are supported by bearings in a gearbox housing, which we make on a mill using 1x3 rectangular aluminum tube with 1/8 inch wall thickness. The output shaft bearings are installed flanges-in with a 1/8 inch plastic spacer between the gear and one bearing. The motor face mounts to one side of the tube* secured by two M4x10 button head screws, then a spacer and the shaft gear go on, and a 3/8" hex bearing (217-2735) goes in flange-out. A 10-32 x 0.5 inch button head screw and washer keep the bearing in.
Free current draw with this method is less than we saw testing with a Versaplanetary, and the gears are easier to keep lubed. It is also easier to integrate this gearbox into our shooter because the output shaft is also a shooter wheel axle, supported by another bearing on the opposite side. Another benefit is that we can select any of several gear ratios that use the same total number of teeth. That includes options smaller than 3:1, which is lowest ratio available using Versaplanetaries.
*Vent holes in the tube wall, aligned with those in the motor face, are highly recommended.
Richard Wallace
since 2003
Unread 23-01-2016, 22:16
kbrowncny's Avatar
AKA: Kevin Brown
Rich, Thank you for the input! We are leaning toward that method. I would like to see your setup. Do you happen to have a finished product?
Unread 24-01-2016, 10:55
Is anything on a FIRST robot ever finished?
The setup we are testing now is pictured here. Please let us know what you think, and offer suggestions to improve.
Richard Wallace
since 2003
Unread 24-01-2016, 18:32
To echo what RC is saying here, we've been doing this for years, with RS550's, 775's, and are planning on doing it with 775 Pro's this year. RC added that part to his inventory based on feedback from us. We press it on to the 775 with the short flange 0.020" from the motor face to reduce the cantilever. We've never had an issue. (Last year's bot had 7 per robot 775's with pinions pressed on as described. We had 0 failures.) With bearings in the new 775 Pro, this should be even less of an issue.
