Go to Post I mean, there is a 40 second period where your alliance has to play defense, so you might as well play it well. - Jeff Rodriguez [more]
Unread 23-01-2016, 20:20
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Legality
Originally Posted by Arhowk View Post
Howso? The bandwidth usage should not depend on the medium of transportation. (If anything, the only difference between the two is that using the usb camera requires roboRIO processor cycles to transfer the data to the router)
JPBlacksmiths is probably referencing your bandwidth being eaten up by the stream as a whole. Make sure you set the resolution/framerate to something that will not overflow your 7mbit allocation, which this year is metered on the radio itself.
Nate
