Go to Post If you think life is fair, you are sadly mistaken. - R.C. [more]
Unread 23-01-2016, 11:14
TheLiterateOne's Avatar
TheLiterateOne TheLiterateOne is offline
Slightly Mad User
FRC #3181
Team Role: Electrical
TheLiterateOne is an unknown quantity at this point
Legality
So our programming team wants to know if it's a viable and legal option to stream video from the robot (keeping in mind the bandwidth limit) without streaming it through the ROBORIO.
Use this thread for other legal questions too I guess.
"If the brain was simple enough to understand, we would be too simple to understand it"
-Steven Smith
Unread 23-01-2016, 11:18
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Legality
If I understand the question correctly, of course you can, for ex. Axis IP cameras go straight from router to wireless, they don't talk to the RIO at all.
No need. If there are other questions than they should be posted in their own seperate threads.
Unread 23-01-2016, 11:56
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Legality
We've sent video to a Beagleboard for processing then through the network, bypassing the rio.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 23-01-2016, 18:17
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the rough
Re: Legality
R.I.P your bandwidth
Unread 23-01-2016, 18:30
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Re: Legality
Howso? The bandwidth usage should not depend on the medium of transportation. (If anything, the only difference between the two is that using the usb camera requires roboRIO processor cycles to transfer the data to the router)
Unread 23-01-2016, 20:20
scca229 scca229 is online now
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Legality
JPBlacksmiths is probably referencing your bandwidth being eaten up by the stream as a whole. Make sure you set the resolution/framerate to something that will not overflow your 7mbit allocation, which this year is metered on the radio itself.
Nate
Unread 23-01-2016, 21:17
AKA: John Cashman
Re: Legality
Yes this is what i'm describing. Also Rio or no rio it still has to connect to your computer through the radio and the FMS, in which you can only use so much bandwidth.
