Originally Posted by Amit3339
Hi guys,
I am looking for a way to have a better control at our drivetrain. We're trying to allow better steering and much more accurate driving. In addition it seems that when both of the Y axes are sending max value( 1, We're using tank drive) the robot doesn't drive straight at full speed. I heard quite a lot about Cheesy Drive or CulverDrive by team 33 but never fully understood how it works. Can someone provide more information about the way those driving methods work? is there a way to have the same result with a tank drive?
Thanks in advance
The critical thing in getting auto or a button to drive straight is sensing when you aren't going straight, and by how much. The most common solution is encoders, one set on each side of the robot. Then, instead of setting a voltage level, you set the same speed using either PID classes on the RIO, or through internal PID controls on the motor controller. Even when used with no additional feedback, this is much better than setting voltage. Even better control is possible by also counting the encoder clicks and adjusting. Note that only Jaguar and Talon SRX support controller-side PID.
The other solution is based on a gyroscope or integrated inertial navigation system such as the NavXP. While I haven't used these, I believe the integrated systems include enough documentation to get you rolling straight, and probably a lot more.
