Go to Post ....FIRST helped me realize how much i enjoy engineering, so that i NEED to do well in my classes if i want to reach my goals. - the_short1 [more]
Unread 13-01-2016, 06:45
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
The Portcullis Mystery
I have looked through the field element construction guides, but can't seem to find definitively what the Portcullis door is like. Is it a lattice of solid bars that you can reach through, or is it a solid piece of clear plastic that has lines drawn on it to make it look like bars?
Unread 13-01-2016, 06:51
samefman samefman is offline
FRC #1676 (Pascack Pi-oneers)
samefman has a spectacular aura aboutsamefman has a spectacular aura about
Re: The Portcullis Mystery
The door is a solid piece of plastic. So your robot cannot reach through bars to help lift it. The bars are just printed onto the plastic for visibility and theme purposes.
Unread 13-01-2016, 06:59
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
What I wonder is how solid it is. Can it take a hit from a speeding robot undamaged because I'm sure it'll get smashed into more than once.
Unread 13-01-2016, 07:56
Branden2648's Avatar
Branden2648 Branden2648 is offline
FRC #2648 (Infinite Loop)
Branden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to all
A few people from my team went to the Manchester kickoff and it is Polycarbonate with Bar decals and a 1x1 box steel tubing frame around the whole perimeter of the door on the back side.
Unread 13-01-2016, 10:47
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
dieDoktor is an unknown quantity at this point
Is it transparent with the bars printed on? Or is it some opaquematerial that has the bars printed on as well?
Unread 13-01-2016, 11:06
aidanl78 aidanl78 is offline
FRC #0078
aidanl78 is an unknown quantity at this point
The Portcullis is a 5lb steel frame with, from what I have read, 1/8in. thick Lexan covering the gaps so no robot can travel through
Unread 13-01-2016, 12:30
Mr. Ackroyd's Avatar
Mr. Ackroyd Mr. Ackroyd is offline
FRC #3044 (OxBe4)
Mr. Ackroyd is on a distinguished road
There are pictures of the field in the thread I posted. You can see through the Portcullis.
http://www.chiefdelphi.com/forums/sh...d.php?t=141594
Unread 13-01-2016, 12:40
It's clear polycarbonate with decorations or stickers on it to make it look like bars. It's completely transparent except for the decals which somewhat hinder visibility.
Unread 13-01-2016, 13:01
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
If it's a similar material to the low side walls, I'd guess it could take quite a hit. Whether the pins holding it into the track can stay together, that remains to be seen.
Is the "printing" sandwiched inside or on one of the outer surfaces? I can see that getting scratched off.
Unread 23-01-2016, 08:27
FRC #6054 (Dukes)
Another question: is their a lip on the bottom of the portcullis door? If so what does it look like? Does a lib stick out perpendicular to the door?
Unread 23-01-2016, 11:24
gryphon97's Avatar
gryphon97 gryphon97 is offline
FRC #5430 (Pirate Robolution)
Rookie Year: 2016
gryphon97 is an unknown quantity at this point
I suggest you take a look at the Field Components PDF file. The details for the Portcullis are in there. Start at page 211. The polycarbonate is on page 221.
Unread 23-01-2016, 22:10
FRC #6054 (Dukes)
After consulting the pages you recommend, I still have no insight into the question. It looks like there is a lip on the CAD render, but I don't see any dimensions or reference to it anywhere.
Unread 23-01-2016, 22:41
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
5 lbs of steel, plus a large sheet of 1/8" polycarbonate. Has anybody build the full device, and if so, are the forces necessary to lift it consistent with what we've been told to expect? I'm thinking 2012, of course. The difference between teams who had access to the full and accurate field and those who built the simple version of the bridge were, well, the difference between winning and losing, mostly.
Remember why you're doing this.
Unread 23-01-2016, 23:14
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Try roughly page 259 in conjunction with 256.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 24-01-2016, 06:27
FRC #6054 (Dukes)
I see the steel tubing, trying to figure out if it is on the neutral zone or courtyard side.
