Go to Post Genius is one percent inspiration and 99 percent perspiration, which is why engineers sometimes smell really bad. - Koko Ed [more]
Unread 23-01-2016, 23:03
paul.dornfeld paul.dornfeld is online now
FRC #5523
paul.dornfeld is an unknown quantity at this point
Bulldozing one boulder at a time: is it legal?
If the boulder is kept in front of the bot with no boulder "inside" it?
Unread 23-01-2016, 23:13
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Bulldozing one boulder at a time: is it legal?
Technically, that would be Herding, and is a valid method of controlling a boulder. As long as you do not control more than one boulder at a time, that is fine.
Unread 23-01-2016, 23:15
FRC #5523
Great! Thank you so much.
Unread 23-01-2016, 23:19
FRC #5523
Follow up.
If I didn't want the risk of foul by driving through my opponent's secret passage, I would have to "heard" the boulder through one of the defenses, which would double up as weakening it (provided all the parameters for weakening are met), true?
Unread 23-01-2016, 23:25
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Originally Posted by paul.dornfeld View Post
Follow up.
Uh, you could probably reread the rules for crossing defenses.
If you cross into THEIR courtyard through THEIR secret passage, it's not risking a foul, it IS a foul. In fact, it's a tech foul if you do it a few times.
The only way you're allowed to enter the opponent's courtyard is through a defense in the OUTER WORKS.
Back on topic: In your situation, I believe that the described method is a valid way to have a ball enter the opponent's courtyard, as you're correct in that you're herding the ball, which is considered control
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
Unread 23-01-2016, 23:33
FRC #5523
Whoa! Thanks for the clarification. Helps a lot.
Unread 23-01-2016, 23:36
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Yes, remember, it's a "secret passage" to get into their castle and bypass their own defenses. Meaning ostensibly only their own alliance knows about it and knows how to use it. As far as your alliance is concerned, it doesn't even exist (which is essentially how the rules frame it).
Unread 23-01-2016, 23:45
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Also relevant is G40:
Originally Posted by G40
A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (e.g. doesn’t completely back out of the OUTER WORKS into the NEUTRAL ZONE)
So, you may herd the boulder up and over a defense, and it can even roll away from you into the courtyard, but you must complete your crossing of the defense right there.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 23-01-2016, 23:53
FRC #5523
Yes, that makes sense. Thank you.
Unread 23-01-2016, 23:54
FRC #5523
Very good to know. Thank you.
