Go to Post I've come to believe that the current alliance selection system is just like democracy. It's the worst system possible, aside from all the other ones. - DampRobot [more]
Unread 24-01-2016, 00:16
Streetbots Streetbots is offline
FRC #4964
Streetbots is an unknown quantity at this point
Hook Mechanism?
My team was wondering if it was possible to shoot a hook at the rail in order to scale the tower. Is that allowed?
Unread 24-01-2016, 00:20
Re: Hook Mechanism?
Can you do it safely, and can you do it without violating the 15" restriction? If you can satisfy both of those, I see no reason to disallow it.
However, doing it safely, legally, and without violating the 15" may be a lot more difficult than you might think. Or it might not.
Unread 24-01-2016, 01:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Hook Mechanism?
Also make sure that you don't toss the hook into the high goal; obvious throwable designs that can grab rung will also hook the goal frame.
Unread 25-01-2016, 20:22
[2040] Keleox's Avatar
[2040] Keleox [2040] Keleox is offline
FRC #2040 (DERT)
Team Role: CAD
[2040] Keleox is an unknown quantity at this point
Re: Hook Mechanism?
In terms of legality, there is nothing against the rules with the actual mechanism. Plus in the last 20 seconds, there's no height restriction.
Unread 25-01-2016, 20:37
Re: Hook Mechanism?
I wasn't talking about the height restriction. The 15" frame perimeter restriction applies at all times.
And an otherwise perfectly legal device can be ruled to be unsafe in operation, rendering it illegal.
Unread 25-01-2016, 20:40
FRC #2040 (DERT)
Team Role: CAD
Re: Hook Mechanism?
Whoops misread that initial post.
