Go to Post I am a geek and proud of it. - +()c|D [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Unread 21-01-2016, 15:49
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Re: Tower Tracker 1.0
Also interested in running this on RoboRio and in C++. Anyone have any luck compiling a C++ WPIlib robot program with some opencv in it? If so, I'd love to hear how you did it.
akablack akablack is offline
akablack is an unknown quantity at this point
Thanks for sharing that! How did you get the opencv libraries onto the roborio? I've been having some trouble with that
Unread 21-01-2016, 15:56
Ronso007 Ronso007 is offline
FRC #3339
Ronso007 is an unknown quantity at this point
wow! Amazing!
I just wish that we had something like that in labview :/
Unread 21-01-2016, 17:29
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Originally Posted by jreneew2 View Post
https://github.com/team2053tigertron...016/src/vision
Its a bit messy, and the algorithm is a bit different, but you can change it easily. Also, im getting resource initialized error after a while. It might be an array error.
Thanks! I will see what we can do and get back in touch with you for any improvements we can make.
Ideally, I'd love to see this processed on board with a raspberry pi or arduino board, but that's version 2.0 stuff.
Unread 21-01-2016, 17:58
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Originally Posted by Ronso007 View Post
wow! Amazing!
It works with labview! all you have to do is output to a network table, and from there you can get the values in labview.
Unread 21-01-2016, 20:03
Quantum Byte's Avatar
Quantum Byte Quantum Byte is offline
Lead Programmer
AKA: Domenic
FRC #4776 (S.C.O.T.S. Bots)
Quantum Byte is an unknown quantity at this point
Nicely done.
So how would you use this to get the values of the contours?
Lets say I want my robot to "auto" shoot when the contours are a specific dimension. Anyway I can do that with this ?
Thanks.
Unread 21-01-2016, 22:02
Head programmer
Originally Posted by Quantum Byte View Post
Nicely done.
Thanks.
I will add in the network table features today since i finally got it to work (longer then expected)
essentially you need to find the amount that your shooter can be off (tolerance) while still "scoring", for instance it can make it anywhere from 6-8 feet from the goal. Then you need to make sure your robot keeps driving until it is somewhere between that tolerance and then it can start its fire sequence. I would recommend looking into a pid drive system for that, its a closed loop drive that would work nicely with this.
Unread 22-01-2016, 06:43
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
We followed 2168's vision example and there precompiled version worked fine for us. Any questions, just ask.
Unread 22-01-2016, 07:55
You might want to look at the Getting Started Window, Tutorials tab, say #8.
Greg McKaskle
Unread 23-01-2016, 14:03
TheGuyWhoCodes's Avatar
TheGuyWhoCodes TheGuyWhoCodes is offline
AKA: Christopher Ariagno
FRC #1806 (S.W.A.T)
Rookie Year: 2015
TheGuyWhoCodes is on a distinguished road
When trying to run the program on the Jetson TK1, I get the error
java.lang.UnsatisfiedLinkError: no libopencv_java2410 in java.library.path
I did the install tutorial off of OpenCV's documentation. We have also verified that it has been working on a Windows machine. I think the reason might be that we don't have the correct *.so file inside of the working directory for OpenCV. Is there anybody that can upload the .so file to verify if that's the problem? The so file we are trying to find in the program is called libopencv_java248.so, and it's inside the directory /usr/lib/
Thank you!
-Chris
Unread 24-01-2016, 02:46
FRC #4118
In case anyone is still daring to try to do vision on the Rio, and wants to put it right in their normal C++ project, I was able to (finally) get opencv to build for ARM and integrate into a WPILib project. Been unable to test on a Rio so far, but at least it builds. Here's an example project with the special opencv build and a file (BuildOpenCV.txt) explaining how to set it up. Was a big PIA for me, so thought i'd leave notes on the steps I went through. You can just throw in your own source files into the project, but make sure to delete/comment out the line #define REAL in WPILib.h, as it creates some conflict of OPENCV. Okay it's 3 a.m I should go to sleep now.
Unread 24-01-2016, 02:52
FRC #4118
If you want more detailed build steps than the 2168 thing from last year, here's a 2016 project with a working (building, at least) opencv on C++ as well as instructions on how to set it up if you want to build it yourself (easiest on Ubuntu or similar) in the BuildOpenCV.txt file.
Unread 24-01-2016, 20:52
FRC #4118
Nevermind, I have no idea what I'm doing.
Unread 25-01-2016, 00:26
Head programmer
why are you trying to run it on a jetson or something else...
Unread 25-01-2016, 00:34
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FYI, anyone looking for a precompiled version of opencv 3.1 for the roboRIO, the robotpy project has had one available since before build season. Works with C++, Java, and Python 2/3 -- very easy to install the shared libraries on the roboRIO through our opkg repo.
https://github.com/robotpy/roborio-opencv
