Go to Post For those of you that think the kit chassis is too weak... It is tough stuff. Those of you that say it is too weak, just do not know what you are talking about. - Paul Copioli [more]
Unread 24-01-2016, 06:22
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Wedge on front of robot
Our rookie team finished building the kitbot, and getting it wired and moving this week. After 15-20 minutes of jut driving it around in the hallway we decided to try to take it over a defence that we had built (Ramparts). The front of the robot slammed into the side.
After taking a closer look, it appears that the robot was about 1/8-1/4 to short to get the clearance needed to start over the obstacle. We are considering adding a wedge to the front of our robot to help lift us over barriers, or cutting a wedge from the underside of the kit frame, as seen in some testing videos here.
We saw success with a 4" tall, 4"deep (45* angle) wedge in a video, but aren't sure that we want/can go with something that size. Have any of you prototyped this, and what were your results?
For the record we are using 8" andymark rubber wheels. We are considering switching out the front pair for pneumatics tires as well. Our robot is back heavy, it that matters.
Unread 24-01-2016, 09:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Wedge on front of robot
I suggest you try it and see how it works. Just make sure it doesn't extend past the frame perimeter.
Unread 24-01-2016, 10:09
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
A lot of teams have done wedges to get themselves over bumps before. If you don't know, the 2012 game had some large see-saw-esque things, and some big bumps (similar to the rock wall) that robots had to cross. The wedge front was a very popular solution. Just remember, and I wish I could tell every rookie team this cause I see it all the time, you have to remember that you need bumpers to fit on the robot! Ensure that the wedge-front doesn't make it impossible to mount bumpers, and that, with bumpers on, the wedge isn't concealed. Best of luck!
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 24-01-2016, 10:42
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
I recommend using some quick prototyping to help solve this. Make a few angle pieces that can quickly be added and removed and then run them over the obstacles.
Unread 24-01-2016, 11:02
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Or extend the frame perimeter to include it.
Unread 24-01-2016, 11:42
edong4273's Avatar
edong4273 edong4273 is offline
Team 2375's Very Own Dong
AKA: Edmund "Dong" Dong
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
edong4273 is on a distinguished road
I would start with prototypes and proofs of concept first just to make sure that it is a working idea. I do believe that out team had the thought of using a wedge under the frame to boost the robot so that it could go over the rock wall.
