Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 23-01-2016, 16:10
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Getting camera feed while doing vision
Our team plans on using the NVIDIA Jetson TK1 with OpenCV for vision this year. However, I also want the camera feed to show up on the SmartDashboard so that the driver can see what the bot is pointing at. I was thinking about sending UDP packets with tower targeting info as well as the image to the RoboRIO, but is there a way to forward the image to the driver station SmartDashboard? I was also thinking we could just add another camera for the driver, but I wanted to have just one if possible.
Unread 23-01-2016, 19:56
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Getting camera feed while doing vision
It's possible, but you need to modify the dashboard to read from the Tegra TK1 instead of the roboRIO. What language dashboard are you programming in? Labview is pretty easy to modify, I don't know about the others.
Unread 24-01-2016, 01:30
FRC #3331
We're going to be using Java for the Smart dashboard
Unread 24-01-2016, 02:29
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
have 2 cameras on the robot, one for vision because the exposure works better when turned down and the other at normal sight so it works...ideally have a usb camera to the jetson and a axis to the router...that way you wont take up any extra processing cycles on either
Unread 24-01-2016, 10:34
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Fauge7: how do you network a Jetson, an Axis, and a roboRio with the new radio? Only 2 ports?
Unread 24-01-2016, 11:10
One Eyed Man
Alright, you're going to have to dig down into the vision code libraries for this one. Unfortunately I don't have it installed to search. You need to search through it to find where it opens the network connection to the roborio on port 1180 and change the IP/name to your coprocessor. I recommend changing the library names when you save it so you have an alternative. In labview I've exposed the port & IP address at the top level so I can change it as desired.
It's legal to run a network switch on the robot so long as the RIO is still plugged directly into the radio on the appropriate port.
Unread 24-01-2016, 11:19
Head programmer
a simple network switch, my team is not using a coprocessor as they are simply not needed for our use.
Unread 24-01-2016, 15:49
fovea1959's Avatar
AKA: Doug Wegscheid
has anyone find a particularly small/light switch that seems adaptable for FRC?
Unread 24-01-2016, 19:20
One Eyed Man
I haven't tried this, but this one seems to meet a few requirements, including able to run off the existing VREG
http://www.trendnet.com/products/unm...abs-solution02
