Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
Unread 13-01-2016, 07:55
ABreyen's Avatar
ABreyen ABreyen is offline
Marketing Head and Team Management
FRC #2232 (Deus Ex Machina)
Team Role: Marketing
ABreyen is a glorious beacon of lightABreyen is a glorious beacon of lightABreyen is a glorious beacon of lightABreyen is a glorious beacon of lightABreyen is a glorious beacon of light
2016 Scouting Ideas/Apps
I know that it's early, but we [our team] wants to get a jump on scouting ideas (and possibly mobile apps) for this year!
My thoughts on mobile apps: (subject to mentor approval &#128540 2014 we had 6 school iPads and 6 dedicated students in the stands, scouting on those iPads. It worked GREAT, I thought, the only issue was iPad security. Our coach could NOT leave the stands, as school policy for off-site tech states that whoever checks it out, is responsible for it.
2015 we used paper... Yuck. Given that 2015 was a confusing scouting year, but I believe iPads were easier.
So, I thought that, most students have iPhones or Android devices. Why not use those? (Again, subject to mentor approval) Obviously, devices CANNOT communicate in match and in arena.
So... Barring any complications w/ approval, are any teams planning on making an iOS 2016 scouting app, or iOS and Android? We would be greatly appreciative of one--as we have no idea how to code an iOS app 😜
TL/DR: Are any teams planning on making an iOS or iOS and Android 2016 scouting app?
Unread 13-01-2016, 08:21
sagi34 sagi34 is offline
FRC #2231 (OnyxTronix)
sagi34 is an unknown quantity at this point
Re: 2016 Scouting Ideas/Apps
IDK about the apps, but last year I was lead scout in my team, and we tried to use app instead of papers, it was first year we did it, so I allowed each student to choose what he likes better, only 1 out of 12 studnets chose the app over the paper.
I think that it is much more comfortable to use papers, because you can use them however you want, and not according to the rules of a specific app, another reason is the battery, you need your phone battery to communicate with your team, you don't want your battery to reach 0% because you used the app, and if it reaches 0%, how will you continue using the app? you will loose a lot of scouting data.
Student: 2013 - 2015
Mentor since 2016
Unread 13-01-2016, 12:02
Farbod909 Farbod909 is offline
FRC #1515
Farbod909 is an unknown quantity at this point
Yes! MorScout 2.0 is a perfect solution for you. It can be used offline or online so you have that freedom in case internet is not working in the arena. Also, you can fully customize your scouting forms so you're not restricted to team 1515's scouting strategy (however, that will still be an option).
Here is the full description:
Team 1515 MorTorq is developing the next iteration of our scouting application, MorScout, from last year. Our scouting application is designed to be run without any setup, meaning your clients will require an internet connection to login and periodically to sync to the server. MorScout is designed to run primarily on Android and iOS, but also web browsers. Each FRC team can create accounts for their own scouters. Our application is designed for both match scouting, as well as pit scouting. Each team can create custom forms for their scouters to fill out, so teams are not limited by just our scouting ideas! Once scouting reports have been made, team members can view all reports from their team for specific matches and/or teams. Additionally, scouters will have the option of making their reports public or private. Private means that only the scouters’ team will be able to review that report. By making a report public, any team using MorScout will be able to view the report, allowing each FRC team to assist in every team’s scouting.
Although MorScout is currently in heavy development, you can view our progress at our Github pages. Our goal is to finish MorScout by Week 1 of FRC competitions.
Server: https://github.com/mortorqrobotics/morscout-server
Web client: https://github.com/mortorqrobotics/morscout-web
Android: https://github.com/mortorqrobotics/morscout-andorid
iOS: https://github.com/mortorqrobotics/morscout-ios
Last year’s version of MorScout is also available here:
https://github.com/mortorqrobotics/morscout-2015
Unread 13-01-2016, 14:15
ABreyen's Avatar
Originally Posted by Farbod909 View Post
Yes! MorScout 2.0 is a perfect solution for you...............
This looks awesome! We will definitely look into this! Are you planning on publishing to Google Play and/or the Apple App Store? Or is it just the source code to have teams compile?
One question: Do the devices talk to each other (via BlueTooth or Wifi or something), or do they sync to a central server to talk to other devices?
This looks awesome!
Unread 13-01-2016, 15:31
FRC #1515
Version 1.0 is available on the App Store and play store, but in order to test them out, you would need to download the server from the morscout-2015 repository and run a local server process.
Version 2.0 will also be on the App Store and play store too. But this time, we will be hosting a centralized server, in order to make using MorScout even easier! All you would have to do is make an account, join a team, and start scouting.
The app syncs the scouting data with the server, and even if there is no internet, it stores the info on the device, and syncs as soon as an Internet connection is re established.
There will be 4 ways to use the app: iOS app, android app, desktop app, and website.
Unread 13-01-2016, 15:54
ABreyen's Avatar
This is exactly what I was hoping for! Im attempting to try it on my devices, and hopefully I can convince the team to use it!!
Unread 13-01-2016, 16:44
FRC #1515
For some reason the morscout-2015 server folder had been removed but I re-added it. If you want to test the mobile apps, you can follow the instructions in the repository to successfully run the server and connect to it via one of the apps.
If you have any issues please let me know. My email is rafezyfarbod@gmail.com
Unread 13-01-2016, 18:08
Adam8234's Avatar
Adam8234 Adam8234 is offline
Controls Captain
AKA: Adam Corpstein
FRC #2052 (KnightKrawler)
Adam8234 will become famous soon enough
2052 has a scouting app. FRC Krawler is not like most scouting apps where it's made for a specific season. FRC Krawler is meant to be used for any season. Meaning, you don't have to wait for updates. Sadly, it's only for Android, so that might not work out for your situation.
Main Advantages:
  1. You can add as many questions, or metrics, as you want. So you only scout what you want. (The main reason why it's so flexible)
  2. Bluetooth Data Transfer across devices
  3. Excel formatted exporting for easy data evaluation
  4. And more...
There are currently 5 metrics with 2 on the way
  • Boolean (Yes or No)
  • Counter ("+" and "-" with an increment for each press of a button)
  • Slider (A seekbar in a range you provide)
  • Chooser (A list that you choose one item from)
  • Checkbox (A list of checkboxes)
Examples of 2052's metrics for 2014...
  • Auto High/Low - 1-3 - Counter
  • Move over Auto Line - Boolean
  • Accuracy - 1-10 - Slider
  • Role - Inbound, Trusser, Finisher - CheckBox or Chooser.
I could go on...
Google Play Store
Check out more here - http://www.team2052.com/frckrawler/
If you have any questions or need help, email frckrawler@team2052.com
FRC 2052 KnightKrawler (Controls Captain, Lead Scouting App Developer)
New Brighton, Minnesota
2017 Lake Superior Regional ?, 10,000 Lakes Regional ?
2016 Lake Superior Regional F, 10,000 Lakes Regional W, 10,000 Lakes Chairman's Award W, Carson Division W, Einstein QF, Minnesota State Championship W
2015 Lake Superior Regional F, 10,000 Lakes Regional F, Galileo Division QF, Minnesota State Championship F
2014 Lake Superior Regional W, 10,000 Lakes Regional W, Galileo Division QF, Minnesota State Championship W
Unread 13-01-2016, 18:24
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
I highly recommend SuperScout. You can check out this thread for more information.
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
Unread 13-01-2016, 18:38
beurwonderwall's Avatar
beurwonderwall beurwonderwall is offline
Drive Coach/Team President
AKA: Michelle Lester
FRC #2959 (CW Tech Robotarians)
beurwonderwall is a glorious beacon of lightbeurwonderwall is a glorious beacon of lightbeurwonderwall is a glorious beacon of lightbeurwonderwall is a glorious beacon of lightbeurwonderwall is a glorious beacon of lightbeurwonderwall is a glorious beacon of light
In my team, we use a combination of paper and an Android app.
The Andorid app is an app we custom write each year and we use it to take data all day Friday and then compile it Friday night.
The paper is used to funnel the drive team much needed information throughout the day.
Personally, we use Telerik Appbuilder to build our app because it is simple and straight forward. We choose Android because it is easier to build an app for.
I highly, highly recommend using an app as it makes the compilation of data much easier.
As for your concerns with the coach not leaving the stands, I would suggest having some sort of system. We have a leadership member or mentor in the stands at all times, so it isn't much of a problem for us.
We also use a rolling box (sort of like a suitcase, but plastic) to keep everything in so we can easily take it to lunch with us.
We also use a convertor to charge the tablets so we never run out of battery.
If you have any questions, feel free to contact me!
Team President, Drive Coach, and Field Captain for Team 2959 (2013-2016)
Marketing Mentor for Team 5484 (2016-???)
Head Coach of FTC Team 12014 (2016-??)
In the process of starting the robot revolution at Saint Mary's College. Go Belles!
Unread 21-01-2016, 19:18
SVanNess's Avatar
SVanNess SVanNess is offline
FRC #1720 (The PhyXTGears)
SVanNess is an unknown quantity at this point
When will Krawler have the 2016 events imported?
Unread 21-01-2016, 20:04
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MR. T)
The Doctor is on a distinguished road
I'm making a scouting webapp to compile numerical data on team performance during qualification rounds. It's a bit limited in that it needs a computer or a tablet with wired internet (because Wifi is disallowed). Like I said, it's only for match scouting, and we'll probably use a separate mobile app or paper for pit scouting.
As stated here, pit scouting is likely much less valuable than actual match scouting. If people are interested, I might publish the code.
Early prototype:
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 24-01-2016, 15:47
Adisai1's Avatar
Adisai1 Adisai1 is offline
AKA: Adi Sai
no team (Undecided (New Team))
Adisai1 is on a distinguished road
Team 226 is working on a scouting app, that is completely offline. It should be ready before at least a week in advance to the week 0.5 competition: http://github.com/hammerhead226/masterfrcscouter.
Unread 24-01-2016, 22:06
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
It's still legal to take advantage of your device's mobile data connection. We are developing Android and iPhone apps that will communicate with an AWS database. (we aren't creating our own network, but taking advantage of one that is already present) A laptop in the pit with a broadband card will keep data updated. In the event that this system fails, the apps also save CSV files with all the data onto individual scouter's phones, which can then be emailed to scouting leadership once the student has access to Wi-Fi. Our app was very successful last season- two teams on Einstein were using it throughout the season .
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 25-01-2016, 23:22
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
We've been using a similar solution. For those who are interested we have white papers on the technical implementation.
