Go to Post Imagine your crate going over Niagara Falls => pack it accordingly (esp if you are attending the Toronto Regional :^) - KenWittlief [more]
Unread 24-01-2016, 17:46
faraz5557's Avatar
faraz5557 faraz5557 is offline
BB-R8ER
AKA: Faraz Masroor
FRC #5557 (BB R8ERS)
Rookie Year: 2015
faraz5557 is an unknown quantity at this point
Eclipse plugins not working
I installed the plugins according to the tutorial [here](https://wpilib.screenstepslive.com/s...clipse-c-java), using the online method for the Java stuff. I already had eclipse before.
However, as you can see [here](http://imgur.com/a/bWqiO), the plug ins are installed but not properly. I can't create a robot project, and when I import the project from our team's Github it gives errors such as 'Unresolved import import edu.wpi.first.wpilibj...." etc. What gives?
Unread 24-01-2016, 23:51
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Eclipse plugins not working
I also had a previous version. I had to start over with a new, clean copy of eclipse. Then after installing the plugins, they worked.
Brian K
Team 1225 Robotics Mentor
Unread 26-01-2016, 11:56
faraz5557's Avatar
BB-R8ER
AKA: Faraz Masroor
Rookie Year: 2015
Yeah that worked. I had to uninstall eclipse (just delete the files) and install eclipse mars from their website. I then removed the project from the workspace and reimported it again.
Unread 04-02-2016, 16:01
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
I have a few students who have the same issues but they are brand new programmers so they don't have previous version installed on their laptops. They claimed to have installed the FRC Plug-in and updates but all wpilibj references are still unresolved. Anyway I can check what they have missed?
Unread 04-02-2016, 18:12
faraz5557's Avatar
BB-R8ER
AKA: Faraz Masroor
Rookie Year: 2015
Check that they have the newest version of Eclipse, which right now is Mars. I had an old version (Juno) so it didn't work. After that, I would review the installation instructions on the website here with them and make sure they did everything on that list. One good, quick test to see if it works right is to try to make a New Project, and in the menu there should be a drop down for "WPILib Robot Java Development." If you don't get this option, there's a problem.
I hope this helps, good luck to your team!
