Go to Post The programmers will kill you if you want that done on the robot!!! - cbeavers6790 [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 24-01-2016, 12:43
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Running different functions at the same time?
Hi,
So we are planning on making a shooter to throw the boulders into the high goal. I need to be able to spin the shooter motor while the pneumatics are being retracted.
My thought would be to have another thread using Python's threading module and just starting a new thread for the motor but I don't know if that is the recommended way of accomplishing it. Here is an example of what I have. I need that for loop to be going while the pneumatics are being set to false.
        if self.arm1.get()==True:
            for i in range(100): #I need this to be on while the solenoids retract
                self.shooter.set(1)
            self.arm1.set(False)
            self.arm2.set(False)
        else:
            self.arm1.set(True)
            self.arm2.set(True)
                self.shooter.set(1)
Thanks!
Unread 24-01-2016, 18:08
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Running different functions at the same time?
There are a number of ways of dealing with this in python. Threads are one of them -- but I generally recommend avoiding threads in robot programming, as it's too easy to get it wrong and there are other ways of doing it that work just as well for many (but not all) problems.
The traditional way of dealing with this sort of thing is through logical constructs referred to as state machines. The idea is to execute the same piece over and over again (but not in a loop),
if self.state == 0:
    do_something()
    if condition_is_true:
        self.state = 1 # this advances to the next stage
elif self.state == 1:
    do_something_else..
Logically, this is the same as your for loop if the "condition_is_true" is checking to see if some count is 100 or not, and you incremented the count each time.
Another way of dealing with this that's unique to python is by using generators (the Yeti framework that team 4819 has does this), but it's more of an advanced topic.
Unread 24-01-2016, 18:30
team-4480's Avatar
Debug? What's that?
FRC #4480
With this method, could I run a motor at full power and at the exact same time be able to control a piston? I feel like the motor would stop spinning while I control the piston.
Unread 24-01-2016, 18:37
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
The good (and bad) thing about motors is if you don't tell them what to do, they'll do the last thing they were told. This means if you forget to set a motor to 0 when you're done with it it will stay turned on. You can use this to your advantage
if state == 1:
    motor.set(1)
    state = 2
if state == 2:
    do_pneumatic_stuff()
    #because the motor hasn't been set to 0, it's still set to 1
    if pneumatic_stuff_done:
        state == 3
if state == 3
    motor.set(0) #Now we set it to 0 to stop it
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 24-01-2016, 18:55
virtuald's Avatar
RobotPy Guy
if state == 1:
    motor.set(1)
    state = 2
if state == 2:
        state == 3
if state == 3
While you're right that this technique works, I highly recommend against it. Instead, I would explicitly set the motor in each branch, so you can be absolutely sure that the motor is doing what you want.
But, you can do something like this:
if self.state == 1:
    self.piston.fire()
elif state == 2:
    something_else
self.motor.set(1)
As you can see, as long as the motor setting is *always* happening and isn't excluded by some if statement, then you're fine.
