Go to Post There hasn't been an announcement to buy pool noodles yet. Considering that they are already out of stores in most of the country, draw whatever conclusion that you like. - Joe Ross [more]
Unread 24-01-2016, 18:44
REVving up for a new season
FRC #2848 (All-sparks)
Re: 775 Pro Coupling
Originally Posted by AustinSchuh View Post
To echo what RC is saying here, we've been doing this for years, with RS550's, 775's, and are planning on doing it with 775 Pro's this year. RC added that part to his inventory based on feedback from us. We press it on to the 775 with the short flange 0.020" from the motor face to reduce the cantilever. We've never had an issue. (Last year's bot had 7 per robot 775's with pinions pressed on as described. We had 0 failures.) With bearings in the new 775 Pro, this should be even less of an issue.
Do you guys have a source for other size gt2 pulleys? I can buy the pinion from WCP, but where do get your others from? (I was hoping mcmaster would sell them).
Also based on it's size it looks like gt2 is close to MXL, any experience in the difference between the two?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 24-01-2016, 18:53
Knufire Knufire is offline
https://www.sdp-si.com/eStore/Catalog
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 24-01-2016, 19:04
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
We buy and broach pulleys from SDP-SI. It is a lot easier only having to source pulleys and not pinions. We previously had issues reliably sourcing pinions. It would be nice to be able to buy hex broached pulleys, but I don't know of a source for that yet.
MXL may be close in pitch size to GT2, but GT2 has significantly higher power ratings than MXL. I don't remember the number (you can find them in the Gates manual if you want), but it is close to an order of magnitude of difference. I doubt that MXL would handle the motor torques, but you should check the numbers yourself.
Unread 24-01-2016, 20:48
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Originally Posted by Richard Wallace View Post
We were also concerned that 775 motors might not handle side loads well.
We've had good results using 3/8 hex shaft stock (217-3310) to fabricate 5mm bore press-fit shaft adapters for the 775pro. Here is our method: (lathe)
-- rough cut stock ~1 inch long using chop saw or band saw
-- face both ends to give 7/8 inch finished length and break edges
-- center drill
-- drill through #21 (0.159 inch dia)
-- drill about halfway through #9 (0.196 inch dia) <-- this step gives a press fit hole diameter for the 5 mm motor shaft
-- tap the smaller end 10-32
-- using arbor press, align squarely and press motor into large end of adapter
(Note: arbor press ram should only touch the back shaft, not the motor body)
A 3/8" hex bore gear on the adapted motor shaft drives a larger gear on a 1/2" hex output shaft. Both shafts are supported by bearings in a gearbox housing, which we make on a mill using 1x3 rectangular aluminum tube with 1/8 inch wall thickness. The output shaft bearings are installed flanges-in with a 1/8 inch plastic spacer between the gear and one bearing. The motor face mounts to one side of the tube* secured by two M4x10 button head screws, then a spacer and the shaft gear go on, and a 3/8" hex bearing (217-2735) goes in flange-out. A 10-32 x 0.5 inch button head screw and washer keep the bearing in.
Free current draw with this method is less than we saw testing with a Versaplanetary, and the gears are easier to keep lubed. It is also easier to integrate this gearbox into our shooter because the output shaft is also a shooter wheel axle, supported by another bearing on the opposite side. Another benefit is that we can select any of several gear ratios that use the same total number of teeth. That includes options smaller than 3:1, which is lowest ratio available using Versaplanetaries.
*Vent holes in the tube wall, aligned with those in the motor face, are highly recommended.
We did the same thing for one of our prototypes. Pressing a short section of 3/8" hex shaft onto the motor has worked great. We hex broached some timing pulleys and secured them with a shaft collar. Being able to quickly swap out pulleys or gears on the motor is really helpful. We used a 0.195" reamer for the hex shaft. This is a little on the tight side, but it goes.
Unread 25-01-2016, 09:30
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by R.C. View Post
If your looking to do that, then its the same as buying the GT2 pulley here:
http://www.wcproducts.net/gt2-timing-pulleys-belts
Can you point me to a C-C distance calculator that works with the GT2 3mm 12 tooth pinions that WCP sells? The one at SDP-SI only goes down to 16 tooth.
I would like to use this pinion to drive a 44 or 45 tooth pulley from SDP-SI. Will exact C-C set up work, or will I need a side tension system to keep six teeth of the pinion engaged to the belt?
Richard Wallace
since 2003
Unread 25-01-2016, 11:30
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
In the past I've just emulated the Versa strategy.
I used the VexPro "c" collar from the Versa and just reamed the pulley to 8mm then applied clamping force from a set screw.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 25-01-2016, 22:22
It's actually pretty easy to do in Solidworks. Draw out the belt as a bunch of arcs with a diameter of (3mm * num_teeth / pi) and straight lines. Use the Path Dimension feature (It's in the drop-down menu in the sketch menu under the Smart Dimension tool) and select all the lines. Set the path length to (3mm * num_belt_teeth). Done!
For short belt runs, you might want to remove a couple thou. We tend to just run exact c-c and move on. For longer ones or more critical ones, we add a tensioner.
Unread 25-01-2016, 22:39
Thanks for the CAD trick -- I will get one of the students to try it!
An equivalent old-school method uses pitch diameter circles and tangent lines connecting them to calculate the wrap angle on each pulley, and then get center distance from the resulting two arcs and two lines. One such calculator can be found here: http://www.gizmology.net/pulleysbelts.htm
Using that one I got 4.773 inch C-C for a 110 tooth belt connecting a 12 tooth pinion to a 45 tooth pulley at 3mm tooth pitch. Will check that against the CAD result before we cut holes in metal. Measure twice ...
Richard Wallace
since 2003
Unread 25-01-2016, 23:56
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
You can change the type of pulley to "timing pulley stocks" to get down as low as 6t. You also have to go to Metric instead of Inch.
EDIT: I got the same result but with only 5 teeth in engagement.
Unread 26-01-2016, 01:48
Our favorite reduction is a 56 : 12 with a 67 tooth belt. I think we might have had 6 of them last year. I love GT2 since there is such a safety factor that it isn't a huge issue if you don't get everything else perfect. (6 teeth of engagement is 180 degrees. I try to target at least 120.)
Unread 26-01-2016, 06:02
Michael Hill's Avatar
We were going to do that. It was all CADded and everything. Then I looked at the load rating of 3mm GT3 belts. They were only rated to 10000 RPM on the faster sprocket (unless I'm reading it wrong). So attaching it to the 775pro with a free speed of >18000 RPM scared me.
Unread 26-01-2016, 10:01
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
-- drill about halfway through #9 (0.196 inch dia) <-- [size="2"][b][i]this step gives a press fit hole diameter for the 5 mm motor shaft
We're looking at how to get a 19t 32dp pinion onto our 775Pro shafts for our shooter. My students effectively designed a clone to the AndyMark Cim-Sim, stealing the shaft, cluster gear, and bearings and using a 19t gear from bane bots that was thought to be appropriate. Long story short, that gear has a 5mm bore, but is also 40dp (we think). As of right now the plan is to modify 19t 32dp gears from AM to fit the 775Pro.
My dilemma this morning was related to fixturing the gear, but also whether to use a #10 drill then ream the bore to .1955" or .1960". This gives you either .0007" or .0012" interference. At this size a proper press fit is .0002" to .0014" interference. If I don't have to spend $40 on tooling it wouldn't hurt my feelings though. My only concern is that a slipping pinion might be pretty difficult to diagnose and could be a pretty severe failure mode in a competition environment.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 26-01-2016, 10:14
I agree with all your points regarding proper interference fit, and reaming is clearly a better method. I think we just got lucky with the #9 drill. Over the past 30 years, I have press fit a lot of motor shafts from 2mm through 17mm diameter and have developed a feel for the forces involved, so I am pretty confident of the results we got on a few motors. I would not use the same method in serial production.
To your question: I'd go with the 0.1955" ream. We will probably do the same when I need to make more components.
Richard Wallace
since 2003
Unread 26-01-2016, 11:15
FRC #1747
Thanks for the input. I'm afraid in the process of removing the improper pinions we may have damaged our motor set, so my intent is to use the .196" drill for this first set of questionable motors to be used in program testing and development, then put in our order for a competition set and back ups for those at which point we may go ahead and get the reamer and take that time.
For anyone wondering, the reamer is McMaster part number 8803A32. You have to specify that you want the .1955" from the range associated with that part number.
Last edited by BoilerMentor : 26-01-2016 at 11:17. Reason: Added McMaster info for reamer.
