Go to Post If you pay attention to every nut job on ChiefDelphi, you'll never reach a decision. - JesseK [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 24-01-2016, 18:55
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Running different functions at the same time?
Originally Posted by TimTheGreat View Post
The good (and bad) thing about motors is if you don't tell them what to do, they'll do the last thing they were told. This means if you forget to set a motor to 0 when you're done with it it will stay turned on. You can use this to your advantage
if state == 1:
    motor.set(1)
    state = 2
if state == 2:
    do_pneumatic_stuff()
    #because the motor hasn't been set to 0, it's still set to 1
    if pneumatic_stuff_done:
        state == 3
if state == 3
    motor.set(0) #Now we set it to 0 to stop it
While you're right that this technique works, I highly recommend against it. Instead, I would explicitly set the motor in each branch, so you can be absolutely sure that the motor is doing what you want.
But, you can do something like this:
if self.state == 1:
    self.piston.fire()
elif state == 2:
    something_else
self.motor.set(1)
As you can see, as long as the motor setting is *always* happening and isn't excluded by some if statement, then you're fine.
