Go to Post Remember, GP doesnt just need to apply to FIRST; if we all apply in our lives as a whole, the world will be a better place. - Dillon Compton [more]
Unread 24-01-2016, 19:49
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: Robot wireless communication cutting out
Check that you are not on the same channel as one of the schools channels. Get a program called inSSIDer from http://www.metageek.com/ to find out.
If your robot network is on the same channel, then you may need to set your equipment to a non-used channel. We had this problem with symptoms you described.
-Hugh
Unread 25-01-2016, 12:55
Ty Gallagher Ty Gallagher is offline
FRC #3538
Ty Gallagher is an unknown quantity at this point
We recently had a similar issue. It was cause my a brown out cause my high current draw from the motors. The issue came up when we added additional drive motors we change from 4 to 6. When driving from stop to full speed it would be fine. It would ocur when quickly changing direction from full forward to reverse or hard left turn to hard right. We corrected the issue added a delay to the code. Before it react immediately to changes in speed, it now takes about 5 cycles before it will reach the requested speed.
