Go to Post Anything is capable of happening in FIRST. - Dorienne [more]
Unread 22-01-2016, 12:10
abster0906's Avatar
abster0906 abster0906 is offline
FRC #0375 (The Robotic Plague)
abster0906 is an unknown quantity at this point
Thumbs up Right Angle Planetary
Does anyone know if there is any type of right angle versa planetary gear box available for purchase (specifically for bag motors)? Thanks in advance for the help!
Unread 22-01-2016, 12:13
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Right Angle Planetary
I don't know of any... But a long time ago, it was common to pull the gearbox off a Dewalt drill and slap it on a CIM motor. There are some right-angle drills available, perhaps you could use one of those in a similar way?
2016: Lake Superior WFFA
Unread 22-01-2016, 12:17
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
You could put a versa planetary into an LJ box from andymark.
Good enough is the enemy of anything great!
team 1671
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Off top of my head:
AndyMark Sells this: http://www.andymark.com/product-p/am-2622.htm
They also sell this, which might replace your entire thing depending on what you're doing: http://www.andymark.com/RAW-Box-p/am-2372.htm
VexPro sells Bevel Gears alone (http://www.vexrobotics.com/vexpro/mo.../217-3344.html
), if you can create a bracket to assemble them that mates to the VersaPlanetary. Not sure what your machining capabilities are, but I know I could make such a thing with some 1/4" aluminum, drillbits, taps, and a drill press, or just sheetmetal capabilities.
Unread 22-01-2016, 12:47
mfalk mfalk is offline
FRC #2172
mfalk is an unknown quantity at this point
This is what we did last year but we used the AM-0002 planetary. Worked well enough but is pretty pricey.
Unread 22-01-2016, 13:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
And if you want really easy to install and don't mind the weight, something like this might work, designed to adapt a hand drill for right angle.
Unread 22-01-2016, 22:07
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Are you specifically asking for a gear box that attaches to the output shaft of a versaplanetary, or are you asking for a simple way to change the motion to be perpendicular to the rotation of the output shaft?
If you're asking for the former, you have been given some solutions by the posters above. If you're asking for the latter, you can simply put a bevel gear directly on the output shaft of the versaplanetary, and have the second bevel gear on the shaft you need to drive. The way you form structure around this is entirely dependent on your design and manufacturing capabilities. I would appreciate a description or sketch of what you wish to do so we can better help.
Here is an example from our 2015 practice bot intake for the latter option:
Unread 22-01-2016, 22:14
Aren_Hill's Avatar
Build Nifty Things
I have some of these torn apart for potential robot use, very light and small actually, and rated for impact use, so good for most things outside of drive.
-Aren
A guy who likes robots.
Unread 24-01-2016, 11:53
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
bEdhEd,
Did you end up having to use a snap ring on the vertical shaft? What keeps it from falling down?
Unread 24-01-2016, 23:23
Mark Buckner Mark Buckner is offline
FRC #4265
Mark Buckner is an unknown quantity at this point
What size hex shaft is this? 3/8" or 1/2"? Thanks
Unread 25-01-2016, 00:19
bEdhEd's Avatar
Originally Posted by MrRiedemanJACC View Post
bEdhEd,
We use these retaining rings
and these shafts are 1/2" hex. You can actually see the retaining ring in the picture if you look really closely.
