Go to Post By seeing other robot designs, teams can plan before hand on how to defend or defeat it. - Don Wright [more]
Unread 24-01-2016, 08:29
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Question Multiple timer objects / deleted timers
Just a quick question for people who know C++ better than me,
I am writing some code for mechanisms on our robot and am trying to have one command for controlling the shooter in teleop and auto modes. I have in OI.cpp:
buttonA->WhileHeld(new ShooterControl(1)); //forwards
With my undertanding, WhileHeld makes a new instance of the command each time the previous finishes.
and in ShooterControl.cpp
#include "ShooterControl.h"
ShooterControl::ShooterControl(float speed, float target)
	// Use Requires() here to declare subsystem dependencies
	// eg. Requires(chassis);
	Requires(Robot::shooterSubsystem.get());
	timer.reset(new Timer());
	timer->Reset();
	timer->Start();
	timeCurrent = 0;
	timeTarget = target;
	inputSpeed = speed;
	isDone = false;
// Called just before this Command runs the first time
void ShooterControl::Initialize()
// Called repeatedly when this Command is scheduled to run
void ShooterControl::Execute()
	timeCurrent = timer->Get();
	if(timeTarget == 0) { //if zero use in teleop mode
		Robot::shooterSubsystem->Shoot(1);
		isDone = true;
	else {
		if(timeCurrent >= timeTarget) {
			Robot::shooterSubsystem->Shoot(0);
			isDone = true;
		else {
			Robot::shooterSubsystem->Shoot(inputSpeed);
			isDone = false;
// Make this return true when this Command no longer needs to run execute()
bool ShooterControl::IsFinished()
	return isDone;
// Called once after isFinished returns true
void ShooterControl::End()
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
void ShooterControl::Interrupted()
Would this code bog down memory because of the multiple instances of the Timer Object? When does a timer get deleted?
Thanks,
Drew
Unread 24-01-2016, 23:25
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Multiple timer objects / deleted timers
If you are worried about weather instances getting deleted I think you should be declaring instances on stack and not the heap. With stack allocation do not have to be explicitly de-allocated. http://gribblelab.org/CBootcamp/7_Me...k_vs_Heap.html
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 25-01-2016, 08:58
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
The new operator creates objects on the heap, which means C++ will not clean them up automatically, and if you lose all pointers to them before cleaning them up you'll get a memory leak. As @teslalab2 said, you can allocate objects on the stack or associated with another object to have C++ automatically delete them when they go out of scope. If you need a heap object but don't want to worry about manually cleaning it up, you can use a std::shared_pointer. To create a shared Timer pointer, use std::make_shared<Timer>()
Unread 25-01-2016, 09:18
jreneew2's Avatar
AKA: Drew Williams
Thank you for the help! I ended up changing them to shared pointers anyway because WPILib switched to them for most of their code.
- Drew
Unread 26-01-2016, 12:26
Just to be clear, a new instance of the command is only created once. It is reused each time the command finishes.
Unread 28-01-2016, 00:07
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
In addition to Joe's point the constructor will only be called once. With that in mind you will likely need to move the following out of the constructor and into the initialize method.
timer->Reset();
timer->Start();
isDone = false;
This will cause them to execute each time the command is ran instead of just once when the robot is started up.
In this particular case (assuming your comments are correct) your command will only run once because isDone will already be true on subsequent executions of the command. The timer will likely also not behave as you expect if you don't reset and restart it in initialize.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
