Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 01-17-2016, 01:22 PM
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
Robotbuilder c++ code dies in Test Mode
Finally got example robot programs to run after Plugin update. Thanx.
Now I tried the most simple RobotBuilder C++ code (one subsystem with one speed controller). exported, imported, built and deployed OK. When I select Test Mode then enable. The Drivers Station indicates Test Enabled for 1/2 second, then Test Disabled. The roborio Mode indicator goes Red, then Comm indicator Red, then Mode goes off and Comm goes back to green.
Unread 01-17-2016, 03:23 PM
Re: Robotbuilder c++ code dies in Test Mode
I've duplicated this. It has to do with the way the SpeedController object is cast to the
Here's the code that causes the crash:
lw->AddActuator("Subsystem 1", "Speed Controller 1", (Talon&)subsystem1SpeedController1);
Here's code that works:
lw->AddActuator("Subsystem 1", "Speed Controller 1", std::static_pointer_cast<Talon>(subsystem1SpeedController1));
I'm not a C++ guru, so I'm not sure if that's the right method to cast the shared_pointer from a SpeedController to Talon or other class that implements a SpeedController.
Unread 01-17-2016, 03:54 PM
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
I think std::static_pointer_cast will work here. The type is definitely a Talon, so std::dynamic_pointer_cast isn't necessary. Note that the pointer passed in can't be that of a stack allocated object or a double-free would occur later.
Is subsystem1SpeedController1 an object or pointer to an object? If the suggested code is correct, then subsystem1SpeedController1 is a pointer and casting to Talon& seems strange to me anyway.
Unread 01-17-2016, 04:09 PM
Here's the full code as RobotBuilder generated (minus the comments)
#include "RobotMap.h"
#include "LiveWindow/LiveWindow.h"
std::shared_ptr<SpeedController> RobotMap::subsystem1SpeedController1;
void RobotMap::init() {
    LiveWindow *lw = LiveWindow::GetInstance();
    subsystem1SpeedController1.reset(new Talon(0));
    lw->AddActuator("Subsystem 1", "Speed Controller 1", (Talon&) subsystem1SpeedController1);
Unread 01-17-2016, 05:09 PM
AKA: rod nelson
Thanks, that worked for me.
Unread 01-18-2016, 10:38 AM
I submitted a patch for review for this for Robot Builder.
Unread 01-20-2016, 03:49 PM
AKA: rod nelson
How do I find out when or if Robot Builder gets revised?
Unread 01-20-2016, 08:59 PM
New software releases are mentioned in team updates, or you can watch one of these pages on screensteps: http://wpilib.screenstepslive.com/s/...ware-revisions or http://wpilib.screenstepslive.com/s/...ugin-changelog
Unread 01-24-2016, 10:03 PM
I think there's an eminent release of the eclipse plugins including robot builder with this fix. However, in the meantime, here's a version with the fix.
Edit: see version below.
Unread 01-24-2016, 11:05 PM
AKA: rod nelson
Did a quick test and it works. Thanx a lot...
Unread 01-25-2016, 12:10 AM
AKA: rod nelson
Still have problem with the most simple c++ program built with new Robot Builder (one generic subsystem with one motor actuator).
old robot builder
std::shared_ptr<SpeedController> RobotMap::subsystem1SpeedController1; // <<< this is ok
lw->AddActuator("Subsystem 1", "Speed Controller 1", (Talon&) subsystem1SpeedController1); // <<< this caused Test Mode to abort
new robot builder
static std::shared_ptr<SpeedController> subsystem1SpeedController1; // <<< this causes a build error
lw->AddActuator("Subsystem 1", "Speed Controller 1", std::static_pointer_cast<Talon>(subsystem1SpeedCon troller1)); // <<< this is OK
Unread 01-25-2016, 12:49 AM
Try this version
Unread 01-25-2016, 10:15 AM
AKA: rod nelson
Try this version
Looks right. I will test on robot this afternoon.
Thanx
