Go to Post The losing alliance should know they lost, admit it, and use the desire to win to push themselves even further. - artdutra04 [more]
Unread 25-01-2016, 00:41
slickvic2252's Avatar
slickvic2252 slickvic2252 is offline
mentor
AKA: Theren Vickery
FRC #2252 (Mavericks)
slickvic2252 is an unknown quantity at this point
Intake cord
What kind of polycord does everyone like to use? Like to find something easy to work with.
Unread 25-01-2016, 00:55
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Re: Intake cord
Polycord is a very popular choice among FRC teams. Do a google search or a forum search to find more information to help you out. If you need help on the easiest way to join Polycord without any special tooling, PM me.
Note that Polycord is a brand name, and these cords you see on most intakes are known as urethane belts.
We source our cord from McMaster-Carr.
Unread 25-01-2016, 06:59
D_Price's Avatar
D_Price D_Price is online now
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
Re: Intake cord
We also source our cord from McMaster as the lead times are nice and short. As to the easiest cord to use, it all depends on how exactly you want to use the cord.
http://www.chiefdelphi.com/forums/sh...ad.php?t=71221
The above forum may be of some help.
+1
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 25-01-2016, 07:02
RonnyV's Avatar
RonnyV RonnyV is offline
All of the above
AKA: Ron Visser
FRC #4481 (Team Rembrandts)
RonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud of
Re: Intake cord
This is the most popular orange belting for intakes that most teams use.
Round belting:
Good example: https://youtu.be/p0_YOm5fjC8?t=1m12s
Flat belting:
Good example: https://youtu.be/1j6Hdi0U5nk?t=18s
For belting this together I find this video very useful from Triple Helix 2363!
It's about how to connect them together if you buy the belting on a roll.
https://www.youtube.com/watch?v=auJt_tmZpao
Logic will get you from A to B. Imagination will take you everywhere.
Unread 25-01-2016, 10:27
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Intake cord
The linked video shows some good tips for joining the belt except DON'T use a flame to heat the urethane. Apart from the general hazard of fire (and that you can't use a flame at competition) BURNING URETHANE PRODUCES TOXIC FUMES.
Simple solution: USE A HEAT GUN instead. Shield areas you don't want to heat with a piece of aluminium. Careful, that will get hot too.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 25-01-2016, 13:14
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: Intake cord
What is the practical difference between the hollow core and solid core belts? Are solid core more commonly used? Do the hollow core deform more easily or do they have a tenancy to "flatten"?
Unread 25-01-2016, 13:53
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Intake cord
The hollow core has the advantage or disadvantage of a mechanical joining system. It hard to push the barb into the tube & you have to be careful not to damage the hose barbs. The solid ones have to be welded. We have always used the hollow ones.
Unread 25-01-2016, 14:02
mentor
AKA: Theren Vickery
Re: Intake cord
Has anyone done any testing with different shores?
