Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
Unread 21-01-2016, 10:52
ryanjacobs's Avatar
ryanjacobs ryanjacobs is offline
AKA: Ryan Jacobs
FRC #1708 (Amp'd Robotics)
ryanjacobs is an unknown quantity at this point
Re: FRC GamePlan Strategy App
Great work guys! The only thing I would suggest is just have some sort of regular menu button to make i more user friendly, but overall, awesome work!
Unread 21-01-2016, 17:21
shadowsnf shadowsnf is offline
FRC #1723
shadowsnf is an unknown quantity at this point
Great app!
Unread 21-01-2016, 22:30
ANiyaz ANiyaz is offline
FRC #0868 (TechHOUNDS)
ANiyaz is an unknown quantity at this point
Version 1.0.3.3 does include this MENU button along with the Double Tap. This update is currently rolling out!
Unread 22-01-2016, 15:23
dibblec's Avatar
dibblec dibblec is offline
AKA: Mr. C
FRC #4824 (BerryBotics)
dibblec is an unknown quantity at this point
Nice job on the app. Looking forward to our team using it.
Unread 22-01-2016, 15:28
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Considering teams only get one match beforehand of time to finalize a strategy based on chosen defenses, I think using Bluetooth and this app to strategize would be fine so long as you are following the rules. I would have the rules related to this memorized or a copy of the rules in case you are questioned by volunteers.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 22-01-2016, 18:08
GMeyer's Avatar
GMeyer GMeyer is offline
Chief Communications Officer
AKA: Grady B. Meyer
FRC #0293 (S.P.I.K.E (Students Participating In Killer Engineering))
Team Role: Communications
GMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud ofGMeyer has much to be proud of
Thumbs up Re: FRC GamePlan Strategy App
Thanks for making this! Our team got the app and it's pretty cool. My team is probably going to use it this season, to replace the whiteboard we were using for a similar purpose last season.
I have only complaint: You can undo your last few changes or you can clear the field, but otherwise, there isn't really a way to selectively erase. This would be a very useful thing to have. I also agree with Jaxom's idea that this should have an "only one for each category" restriction with regard to the defenses. Otherwise, the app is great, and I love it's simplicity. Very easy to use, and to learn to use.
Unread 23-01-2016, 01:31
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by The Doctor View Post
T4 only disallows 802.11 networks... Not to mention that the FMS uses 5ghz wifi and bluetooth is 2.4.
Folks,
Just in case there is any confusion ...
In earlier posts, when I wrote that you should not [plan to] send anything from the stands to the field - I had in mind the restrictions imposed by G29 and T26-1.
Those two forbid creating even the possibility of communication to the field from anywhere else. They don't care what physical layer protocol (Bluetooth, WiFi, whatever) might be involved. Their point is that no devices capable of communicating are allowed. And ... If no communication devices are allowed at the field, planning to communicate from the stands to the field would require violating a rule.
I'm being a little imprecise when I use the term "field" to paraphrase the terms actually in the rules, but in practical terms, when you are leaving the pre-match queue, it's time put all communication devices away. At that time, if you haven't drawn, printed, or memorized your shared plan, I don't think that you will be allowed to use a loose phone or tablet to display it.
If I'm wrong, and there is a way to display a plan on any typical general-purpose computing device, please let me/us know. I presume that using a tablet, laptop, phone, etc. would require convincing the referees both that all the communication capabilities on the device had been successfully disabled before the device reached the field, and that those capabilities would unambiguously remain disabled while the device was at the field.
Am i overlooking some other pertinent rule?
Blake.
Unread 23-01-2016, 20:06
Lidor51's Avatar
Lidor51 Lidor51 is offline
AKA: Lidor Kaplan
FRC #1577 (Steampunk)
Lidor51 will become famous soon enough
Cool and very useful app!
I'm using LG G4 and the app doesn't run smooth, there are two bugs:
1. I can drag robots/boulders only on Y axis.
2. If I want to change a specific defense, I need to touch one defense left from it.
Do you know to explain it? Someone else had this problem?
2012 – Driver & Progammer.
2013 – Team Captain & Driver.
2014-Present – Mentor.
Steampunk 1577, Israel.
Facebook Youtube Website
Unread 25-01-2016, 09:44
Thanks! GamePlan developer here, I was able to test the app on an LG G4 and I unfortunately did not see the above problems happen. Maybe try updating the app to Version 1.0.5?
Unread 25-01-2016, 11:49
Lidor51's Avatar
AKA: Lidor Kaplan
The last version I see on Google Play Store is 1.033..
Unread 25-01-2016, 11:51
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
It works great on my G4
Unread 25-01-2016, 12:21
Daria Wing's Avatar
Daria Wing Daria Wing is offline
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
Daria Wing is an unknown quantity at this point
Just downloaded the app! Looks great and can't wait to play around with it a little more. Would appreciate an eraser tool. Also, I cannot figure out how to move the robots around. Other than that. Awesome job.
Unread 25-01-2016, 12:26
Much appreciated! Thanks! You have to hold the robot in the menu for like a second and then it will automatically pop a robot up on the field that you can drag with your finger. You delete them by dragging it into the castle.
Unread 25-01-2016, 12:29
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Thanks for developing this Atif and Techhounds!
1058 PVC Pirates 2016 - xxxx
Unread 25-01-2016, 17:40
Dibit1010 Dibit1010 is offline
FRC #0587
Dibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond repute
PLEASE MAKE AN IPHONE VERSION
