Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 25-01-2016, 10:12
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Talking Re: Using the Jetson TK1 with LabView (sort of)
Originally Posted by doctorflems View Post
Hello, everyone--
Shouldn't it be possible to program the JTK1 in Java, and have it feed the results of the image processing to the RoboRIO over some form of serial communication?
While it would be possible to program some vision code in Java, to utilize the GPU of the Jetson TK1 and all of the opencv customization NVIDIA built into the OpenCVforTegra you would need to use C++.
For communications there are many options.
Originally Posted by marshall View Post
Before you pick one... ask yourself what data you are sending and where, and why you are sending it. Some data that gets sent does not always need to get sent...
We used NetworkTables last year but we've found it to be slow for our purposes this year so we are investigating alternatives.
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
