Go to Post I saw Dave Lavery on the Webcast. And he winked at me! - Tetraman [more]
Unread 25-01-2016, 11:59
Ronso007 Ronso007 is offline
FRC #3339
Ronso007 is an unknown quantity at this point
Re: Brightness on 2016 vision samples
Originally Posted by Greg McKaskle View Post
The WPILib Camera VIs were originally written for the Axis VAPIX API. When USB cameras were added, they were added via the NI IMAQdx libraries. About half of the properties return a "not supported" error, but some others were extended to have a custom setting.
Lately, I've been using the Vision Acquisition express block configuration. It leads through five wizard screens with a test mode to view the changes as you experiment. It then generates code for IMAQdx. Once done, I will generally right-click and Open the Front Panel which will convert it to a VI. This gives a good starting point for more advanced configuration.
To darken, you can make adjustments to exposure, gain, and brightness.
Greg McKaskle
Originally Posted by adciv View Post
The FRC update for Labview has VIs for setting these. They aren't as nice as I'd like, so I've been working on reading the limits directly and developing my own.
Originally Posted by Bpk9p4 View Post
we were wondering this same thing. We looked into it and from what we can tell you can change the settings using a program however i do not think you can save the settings. Has anyone solved this issue
Is there an easier way? we getting trouble connecting the vision acquisition to the dashboard image loop
