Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 25-01-2016, 12:04
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Rookie Year: 2015
Robomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to all
Re: can the 2015 dlink be reprogrammed for 2016
Yes. The old Dlink works with the new 2016 environment. We are using just that for our software development platform.
Unread 25-01-2016, 12:38
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
For home/shop use only, can you not just use any router that can provide DHCP to your RoboRio and your driver station laptop?
Unread 25-01-2016, 12:44
Yes, you can use any router you want to at home.
It's just a router/AP, nothing special.
You don't even have to change the router IP to a 0. address, it's just usually convenient to do so.
DHCP serving 10.te.am.20 and higher addresses (or similar) is all that's necessary.
I use all my old outdated home AP/router/DSL/whatever to run old robots.
Unread 24-02-2016, 02:45
cartwrig cartwrig is offline
FRC #1720
cartwrig is an unknown quantity at this point
What happened to Team 358's website?
We had bookmarked lots of good info, back during Fall 2016; and, then every time we wanted to refer to some info on your website for the past 6 weeks it was gone....the whole site, in fact.
Thanks,
- Rob
Unread 24-02-2016, 08:24
About 2 weeks into build season our hosting service couldn't handle it any longer, so we are switching to a new service.
But with how busy build season is I just haven't had time to redirect the nameservers.
It'll get done soon, after I've had a bit of a rest.
The site is mostly available via the Wayback Machine
