Go to Post The FIRST community will always step up in times of need. - nikeairmancurry [more]
Unread 25-01-2016, 12:54
Ronso007 Ronso007 is offline
FRC #3339
Ronso007 is an unknown quantity at this point
USB-Camera lower exposure
Hey guys, I have a simple question: how to lower the exposure in the usb camera lifecam HD 3000?
Unread 25-01-2016, 13:08
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: USB-Camera lower exposure
Under: WPI Robotics Library->Camera->Camera Properties Look for the one that says "Set Expos"
Unread 25-01-2016, 13:09
Look in the Vision Processing.vi
One of the settings there is Camera Set Expos.
You can saturate the exposure by pointing the camera at something brighter and use Hold Current.
Look at the Context Help for that library vi for help.
Unread 25-01-2016, 15:14
FRC #3339
Is there a way to use the Set Expos VI with the dashboard?
Unread 25-01-2016, 15:20
You could, it would take a little work.
Make a control or use one of the sample ones on the Dashboard for your code to read on the roboRIO.
In your roboRIO code when the button changes call Set Expos with the camera reference.
Unread 25-01-2016, 15:27
FRC #3339
Can you be specific how to do that?
Unread 25-01-2016, 15:54
  1. Start with a default project (you can add other stuff if you want to).
  2. Look in Teleop.vi for the DB/Button 1 code (with the Sample Boolean 1 output)
  3. Copy that snippet of code to the Vision Processing.vi, inside the While loop
  4. Add a separate Case statement inside the While Loop
  5. Wire the same output that feeds the Sample Boolean 1 output to the Case
  6. Copy the Camera Set Expos into the Case True case.
  7. Wire the Set Expos to the pink camera ref that comes in the left of the While Loop
  8. Change the Set Expose input constant to "Hold current"
Once you've put the new code onto the roboRIO, go to the Dashboard Basic tab and press DB/Button 1 to make the camera Hold Current exposure setting.
This would only work once and assumes that the original Set Expos is still set to "Auto".
Once set to Hold current exposure, then if you push the button a second time you won't se any change.
To get it to change again you'd need to add another Set Expos to take it back to "Auto" long enough for the camera to adjust the exposure again, then you could Hold Current again.
Unread 25-01-2016, 16:56
Here is what I'd do.
Use slider zero and button zero on the basic tab for the camera exposure. These values are automatically stored as "DB/Slider 0" and "DB/Button 0" and if your robot reads those network table variables, it gets the slider values.
Within your camera loop, in the enabled case, the code already updates the image size. Similarly, you can update the exposure by reading the button and slider and calling the Set Exposure subVI. It internally checks against current value and only modifies the camera on change.
Greg McKaskle
Name:	From Clipboard.png
Unread 27-01-2016, 05:04
FRC #3339
Greg McKaskle
Thank you guys for your AMAZING answers!
One last thing, the set Expos sub-vi input is in precentage values and when we put 0 precent it's really dark and when we put any other number it's normal(1,10,50,0.5)... any ideas what is the range?
Unread 27-01-2016, 07:23
It will be camera specific. Vision Assistant will show you the range values of the camera exposure, and the percentage is scaled between their min and max values for that property.
Be sure to have enough light that the camera will actually use your value. Testing a camera in varying light can be confusing, as the cameras decide to outsmart you and send you chasing after untamed geese.
Greg McKaskle
Unread 27-01-2016, 09:14
robert1356 robert1356 is offline
AKA: Robert Palmer
FRC #3824 (RoHAWKtics)
robert1356 is an unknown quantity at this point
This does NOT seem to work. See http://www.chiefdelphi.com/forums/sh...d.php?t=142633 - I'm using the setExposureManual() and setBrightness() methods on the USBCamera class and I'm not seeing a change.
Unread 27-01-2016, 10:55
One Eyed Man
Just checking, are you using Labview or C++?
Unread 27-01-2016, 17:33
AKA: Robert Palmer
Neither - Java, though the C++ and the Java API should be the same.
