Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 24-01-2016, 20:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
pic: 57's frame is coming along
Unread 24-01-2016, 20:29
Owen Busler's Avatar
Owen Busler Owen Busler is online now
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: pic: 57's frame is coming along
What are the dimensions of those pneumatic wheels?
Owen
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 24-01-2016, 20:32
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Owen
7.65" (200mm) diameter. They are Andymark hubs with the black version of the same tires used by AndyMark.
Unread 24-01-2016, 20:33
Those are 8" wheels. To head off the inevitable next question, that bit of framing is about 13" wide and 15" long.
Unread 24-01-2016, 21:08
Aidan H.'s Avatar
Aidan H. Aidan H. is offline
Unregistered User
FRC #3260 (SHARP)
Aidan H. will become famous soon enough
Just wondering (we have been working through our first year of a riveted WCD), how are you planning to run chain with those 2in tall cross members in the space between axles? Are you going to use extra large sprockets, outer chain, or individual wheel motors? Or are you dreaming up some fancy chain routing?
Also, if you are going to be running chain, are you planning on #25? We learned the hard way that it might not be strong enough for flying over defenses, flat out shattering a few links. We know "flying" over them is probably not best for any drivetrain, it'll inevitably happen a few times even if drivers are careful, but if a drivetrain can't handle that, there's going to be failures.
2016 - Greater Pittsburgh Regional Engineering Inspiration Award
2014 - Greater Pittsburgh Regional Winner
2013 - Pittsburgh Regional Finalists
2013 - Buckeye Regional Finalists
Unread 24-01-2016, 21:15
Billfred's Avatar
Billfred Billfred is offline
I can't speak for Kevin, but I'd probably be giving chain-in-tube a look for this configuration.
Unread 24-01-2016, 21:25
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We've done the WCD, riveted chassis, and chain-in-tube before. With this, I'd probably just resign to putting the chains on the wheel side. Big sprockets means chain will be dragging on the defenses, which is definitely not what you want. However, with chain-in-tube, if something goes wrong, it's a nightmare to fix.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 24-01-2016, 21:28
Aww drat, a serious question. I was hoping to string people along for a bit longer. This is actually the frame for our ball intake, with 8" pneumatics outside instead of 4" colsons inside.
In answer to your actual question, our chassis is also 6wd west coast pneumatics., still on 1x2. Our usual solution is wheels outside belts inside. Any inner cross pieces are bolted to the top of the wheel rails. A belt on a 30 tooth pulley will just barely sneak underneath the top of a 1x2. With smaller wheels, we'd run a smaller pulley, but a 24 tooth on 8" wheels would be trouble. I'm mildly concerned about 9mm wide belts on the 30s as it is. We're going to seriously exercise things and see if we need to move up to 15mm wide.
I know other options are to make a belly pan and run belts just above that, or square up your frame with cross pieces fore and aft of the belt paths.
If you drastically over size your belts, you could probably get away with running them around cross pieces that would need removing to replace the belts if I did that, I'd also leave 2 spares also trapped around the cross pieces and ready to slide over and replace a broken belt. And make sure the cross piece is removable over a lunch break.
As for chain, it's been a while since we've had a chain drive. Maintenance on chain drives was trying and failures were costly. We switched to belts a few years back and haven't looked back.
Unread 24-01-2016, 21:43
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Looks eerily similar to ours.
Unread 25-01-2016, 10:54
Lexlukener's Avatar
Lexlukener Lexlukener is offline
Project Manager/Lead Engineer
AKA: Luke Buckner
FRC #4265 (Secret City Wildbots)
Lexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to all
Can I ask where you got the black version of the andymark pneumatic wheels?
Luke Buckner
FRC Team 4265
Unread 25-01-2016, 11:00
The interwebs. (Amazon, specifically)
Unread 25-01-2016, 12:43
Brandon Holley's Avatar
Originally Posted by Kevin Sevcik View Post
Have you found any issues in initial testing that shows a scuffing problem with carpet?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 25-01-2016, 13:02
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Hi Kevin,
I would be interested to know how "bouncy" they are at different psi
success is not hocus posus, it's focus focus
Unread 25-01-2016, 13:03
roboLovr123 roboLovr123 is offline
Junior Member
roboLovr123 is infamous around these parts
ROFL
Unread 25-01-2016, 14:44
we're getting our actual chassis together with those wheels weds and should be doing some driving on saturday. (This week's build schedule is interrupted by my dad retiring on Thursday)
So I can have answers to performance questions around then.
