Go to Post You know you have FIRST Kickoff fever when you know when Kickoff is but not Christmas. - Jacob.B [more]
Unread 25-01-2016, 17:21
Snapperbot Snapperbot is offline
FRC #4501 (Humans)
Snapperbot is an unknown quantity at this point
Question Compatibility with the Analog Devices Gyros
So the ADXL362/ADXRS450 and the ADIS16448 gyros came today from FIRST Choice. I was really exited until I saw that the website only talks about LabVIEW code. Can a team that uses another programming language like Java still get some kind of use out of the gyro or is it as useful as a brick(to teams that don't use LabVIEW)?
Unread 25-01-2016, 17:28
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Compatibility with the Analog Devices Gyros
There is an ADXRS450 class in Java and C++ that will work out of the box with the ADXRS gyro. I do not know for the ADIS16448 gyro however.
Team 4488 - Mentor 2013-2016
Unread 25-01-2016, 18:10
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
As Thad stated, ADXL362/ADXRS450 support is included in both C++ and Java WPILib. C++ and Java code for the ADIS16448 is available at the same location as the LabView code: https://github.com/juchong/ADIS16448-RoboRIO-Driver . The ADIS16448 driver has a Kalman filter implementation but it does not currently do magnetic disturbance rejection (patches to fix this would be welcome).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 28-01-2016, 18:33
FRC #4501 (Humans)
Smile Re: Compatibility with the Analog Devices Gyros
Yea the ADXRS450 worked fine after updating the plugins, I'm having trouble figuring out where to put the java code for the ADIS16448 so I'll just stick to the ADXRS450 for now. Thanks for your help
Unread 30-01-2016, 23:37
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Can you elaborate on the ramifications of not doing "magnetic disturbance rejection"?
Thanks,
...Duane
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 31-01-2016, 00:31
WPILib Developer
The magnetometers in the device sense magnetic fields and are used in the Kalman filter to stabilize the gyro and derive a magnetic heading. Not doing disturbance rejection means that strong magnetic fields (such as those caused by motors) will result in incorrect heading readings.
Unread 31-01-2016, 01:10
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Peter Johnson View Post
The magnetometers in the device sense magnetic fields and are used in the Kalman filter to stabilize the gyro and derive a magnetic heading. Not doing disturbance rejection means that strong magnetic fields (such as those caused by motors) will result in incorrect heading readings.....
..... The ADIS16448 driver has a Kalman filter implementation but it does not currently do magnetic disturbance rejection (patches to fix this would be welcome).
Do you know if these patches are currently under development? It would certainly be nice to have them.
Unread 31-01-2016, 15:55
duane's Avatar
So, what does that mean for us using these devices with C++? Can you elaborate on what interfaces will be useful and which will not? Or is using this device in C++ just not going to be useful?
In short, should we bother using the ADIS16448 IMU with C++? If so what can we use reliably?
I'm certainly not qualified to add the compensation needed for these devices.
Thanks
Duane Murphy
Mentor - Software
Unread 31-01-2016, 16:06
Using the gyro readings alone should be fine. If you want to try using the Kalman derived heading, you should mount the device as far away from motors and moving steel as possible then test heavily to see how it performs, especially driving around steel like most of the field this year.
Unread 31-01-2016, 16:17
duane's Avatar
Thank you!
Duane Murphy
Mentor - Software
