Go to Post I implore you to not spend your mental energy on preparing your argument for the inspectors. We all have better things to be thinking about and working on. - mrnoble [more]
Unread 25-01-2016, 17:43
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Max Digital IO signal rate
Hello CD folks,
I am curious what the current tested maximum rate is for the DIO lines on the RoboRIO? The electrical specifications show a min pulse width of 20ns which would relate to about 25Mhz.
What is the maximum rate that anyone has tested these signals.
Thanks.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 25-01-2016, 18:16
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Max Digital IO signal rate
I don't have much to add for experimental results (most I've pushed is about 120hz), but I question any design that would rely on anything remotely close to the limit of the RIO. Is this more of an educational question or a crazy-design question?
All opinions are my own.
Unread 25-01-2016, 18:21
Knufire Knufire is offline
At least on the cRio, you had to be mindful of the resolution of the encoder you put on a flywheel.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 26-01-2016, 15:59
feverittm's Avatar
This was not an idle question. While I am not considering running anywhere close to the limit, I also wanted to see how the max frequency compared to the max signal rate from our sensors. I was looking for what people have seen in the past.
Floyd Moore
Unread 26-01-2016, 17:59
Back in late November of 2014 I heard the FPGA DIO sampling frequency was going to be bumped up from ~153KHz (2014 Season) to ~1MHz (2015 Season).
Can anyone confirm that this happened?
