Go to Post Are you saying you want to submerge your circuit board in an open container of liquid nitrogen? - Ether [more]
Unread 25-01-2016, 18:21
Knufire Knufire is offline
Re: Max Digital IO signal rate
Originally Posted by joelg236 View Post
I don't have much to add for experimental results (most I've pushed is about 120hz), but I question any design that would rely on anything remotely close to the limit of the RIO. Is this more of an educational question or a crazy-design question?
At least on the cRio, you had to be mindful of the resolution of the encoder you put on a flywheel.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 26-01-2016, 15:59
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
This was not an idle question. While I am not considering running anywhere close to the limit, I also wanted to see how the max frequency compared to the max signal rate from our sensors. I was looking for what people have seen in the past.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 26-01-2016, 17:59
Back in late November of 2014 I heard the FPGA DIO sampling frequency was going to be bumped up from ~153KHz (2014 Season) to ~1MHz (2015 Season).
Can anyone confirm that this happened?
