Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 25-01-2016, 18:44
michelleacao michelleacao is offline
cultho
FRC #1683 (Techno Titans)
Team Role: CAD
Rookie Year: 2016
michelleacao is an unknown quantity at this point
What is the best way to acquire winches?
Hello, I'm from Team 1683 Techno Titans, and we were wondering if it would be better to buy or build our own winches, and if we were to buy them, what would be the best place to buy them?
Unread 25-01-2016, 20:09
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Rookie Year: 2015
Robomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to all
Re: What is the best way to acquire winches?
Team 5771 made a winch for Recycle Rush using an AndyMark gearbox. We bought a second output plate and a longer shaft. We fabricated the bottom plate for attachment to the robot and holding the second output plate. We used hubs for the takeup spool. Worked great. Could lift a 195 lb student.
Unread 25-01-2016, 23:21
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Originally Posted by squirrleluvr123 View Post
The best way to acquire witches is to get a white candle and say " powers of the witches rise a course unseen across the skies come to us I call u near come to us and settle here". If that doesn't work then say "Power of the witches rise. Course unseen across the skies. Come to us, we call you near. Come to us and settle here. Blood to blood, I summon thee. Blood to blood, return to me." On a blood moon when the planets align during a lunar eclipse.
White candle?! I thought we were suppose to sacrifice our motor controllers and release that magic smoke?
Unread 25-01-2016, 23:39
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Michelle -
Here is an example of a winch that is a combination of both options. This one used a worm gearbox from Stock Drive Products to reduce the CIM motor. The advantage of the worm is that it can hold the load without backdriving, allowing you to avoid stalling your motor to hold position.
If you're using the winch to lift the robot at the end of the match, this may be advantageous.
There are tons of examples across CD-Media of teams who have made winches for very similar applications. Just search "Winch" and you should get some good ideas.
If you have follow up questions, do feel free to ask.
Good luck!
Collin Fultz
Unread 26-01-2016, 17:51
cultho
Team Role: CAD
Rookie Year: 2016
Originally Posted by Collin Fultz View Post
Michelle -
Good luck!
Thank you for the advice!
Unread 26-01-2016, 22:05
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Lesson Learned: After our 2013 Practice Robot came crashing down during practice, be sure your winch can't be back driven. Ensure that when the match ends, there is something which autonomously will stop it using method which doesn't require operator intervention. The poor robots drive train was never straight again after that.
Unread 26-01-2016, 22:06
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
we used a window motor directly to two hubs that we used a spools, then we made a box to support the shaft that the hubs were on at both ends
Unread 26-01-2016, 22:39
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
If building one, throw a wrench in the system (literally). A ratcheting wrench can provide the ability for the motor to wind then stop (without stalling) and the wrench would take the load - would require a shifter though. We used this in 2014 for winding and releasing our shooter that year.
