Go to Post "When you lose you don't say anything. When you win you say even less." - Clinton Bolinger [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
  #31   Spotlight this post!
Unread 25-01-2016, 15:09
pnitin pnitin is offline
pnitin is infamous around these partspnitin is infamous around these parts
Re: Tower Tracker 1.0
you can do this on $35 Raspberry pi and save critical RoboRio resources
see this
Look here for tracking shronghold goalpost
http://www.mindsensors.com/blog/how-...our-frc-robot-
  #32   Spotlight this post!
Unread 25-01-2016, 15:17
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
see this
if your trying to advertise atleast make sure the link works...
  #33   Spotlight this post!
Unread 25-01-2016, 16:47
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Originally Posted by Fauge7 View Post
why are you trying to run it on a jetson or something else...
I'm still gonna try to see what I can do with the Rio. I just have no idea what I'm doing when it comes to cross compiling huge C++ projects and make files and shared libraries and all of that stuff.
  #34   Spotlight this post!
Unread 25-01-2016, 16:58
FRC #4118
FYI, anyone looking for a precompiled version of opencv 3.1 for the roboRIO, the robotpy project has had one available since before build season. Works with C++, Java, and Python 2/3 -- very easy to install the shared libraries on the roboRIO through our opkg repo.
https://github.com/robotpy/roborio-opencv
You, sir, just made my day. Been trying to figure out how to build a more up-to-date version of OpenCV for two days now, and realized I have no idea what I'm doing. You RobotPy people really rock.
Now, would you be willing to help me setup my build environment for cross compiling an OpenCV program in C++ that will use the shared libs on the RoboRio (preferably in Eclipse)?
EDIT: Information on setting up build environment is avaible on the latest release on gituhub. Wow, that was easy!
  #35   Spotlight this post!
Unread 25-01-2016, 17:30
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
Can this work with usb cameras?
  #36   Spotlight this post!
Unread 25-01-2016, 18:36
Turing'sEgo Turing'sEgo is offline
Turing'sEgo is on a distinguished road
*My java opencv is a little rusty*
Here is how you use a use camera with the opencv libraries and store the image in the data type Mat.
VideoCapture camera = new VideoCapture(0);
Mat frame = new Mat();
camera.read(frame);
instead of
videoCapture = new VideoCapture();
//replaces the ##.## with your team number videoCapture.open("http://10.##.##.11/mjpg/video.mjpg");
  #37   Spotlight this post!
Unread 25-01-2016, 19:18
Head programmer
Yes, if you are going to use a usb webcam I would recommend mjpeg streamer and running it off of the driverstation.
  #38   Spotlight this post!
Unread 26-01-2016, 18:54
  #39   Spotlight this post!
Unread 02-02-2016, 19:04
MekhiThomas MekhiThomas is offline
FRC #3929
MekhiThomas is an unknown quantity at this point
My team is trying to use your code to test our vision but every time we run the executable JAR file we get two errors-
"Error opening file </build/opencv/modules/videoio/src/cap_ffmpeg_impl.hpp:578>" and when we try to use the network table, we get the error "NT: Error: could not resolve roborio-3929.local address <TCPConnecotr.cpp:93>". We've installed opencv 3.1 and we are able to stream camera output to the dashboard. We are using the microsoft livecam 3000. Any help would be appreciated. Thanks!
  #40   Spotlight this post!
Unread 03-02-2016, 18:29
KaiFukuyama KaiFukuyama is offline
FRC #4327 (Q Branch)
Rookie Year: 2015
KaiFukuyama is an unknown quantity at this point
My robotics team is also getting the same error that everyone else is. When we try and run it in the command prompt is gives us the error that it is having a hard time with having Open CV in the library. It can't find it but it is in there. Any ideas on how to fix it? We followed the directions as it said and nothing works. We also added the DLL file in Open CV folder to system 32. I included a screenshot of the error we were getting. Please help.
  #41   Spotlight this post!
Unread 03-02-2016, 18:36
Head programmer
If its having problems with the ffmpeg you need to download opencv and follow my instructions at the top of this thread. I decribe what you have to do after installing it. As for the microsoft usb camera you have to use whats called mjpeg streamer. It takes a usb webcam and outputs the feed to a web page in which you can call later.
Originally Posted by KaiFukuyama View Post
[font="Times New Roman"]When we try and run it in the command prompt is gives us the error that it is having a hard time with having Open CV in the library. It can't find it but it is in there. Any ideas on how to fix it? We also added the DLL file in Open CV folder to system 32.
Did you extract the program into a runnable jar and then put it in a folder with the files similar to the screenshot i included?
  #42   Spotlight this post!
Unread 04-02-2016, 07:41
Rookie Year: 2015
We figured out what the problem was with why it won't run. We needed to put the Open CV jar file in with system 32.
  #43   Spotlight this post!
Unread 05-02-2016, 01:01
Head programmer
that or you put it in the same folder like i have...Cheers on getting it to work!
  #44   Spotlight this post!
Unread 05-02-2016, 16:18
SlittyEyes SlittyEyes is offline
FRC #3929
SlittyEyes is an unknown quantity at this point
I modified the code to output distance values to the network table. When I add code to put the distance value on the dashboard, no values show up. Also, when I use the OutlineViewer to check any networktable values (with the localhost as "roboRIO-3929-FRC.local"), nothing shows up except the Root folder. Did you get the network table to work?
  #45   Spotlight this post!
Unread 08-02-2016, 21:33
Head programmer
Before checking you need to make sure your program connects to the network tables on the robot. Here is what you can do to ensure that it will connect before it does the vision processing.
while(!NetworkTable.isConnected()){}
