Go to Post It doesn't always work when you put the word gracious in front of anything. Think Battle bots, after a winning match do ya go over to the loser and go we Graciously kicked your butt!? - Alex Cormier [more]
Unread 25-01-2016, 21:38
jweston's Avatar
jweston jweston is offline
FRC #1124 (The Überbots)
Rookie Year: 2015
jweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to behold
Radio wifi packet loss
Hoping someone can help us with our radio. We have our roboRIO hooked up to a OM5P-AN. We get a lot of packet loss when we are connected via wifi, significant enough to interfere with manual motor control (i.e. motors will stop turning for a second or more).
We don't experience loss when the driver station laptop is plugged into the roboRIO via ethernet or USB nor does it happen when the driver station laptop is connected to the radio via ethernet.
After checking the battery and wiring to make sure everything was well-connected and powered, we tried the following with no effect:
- swapped out the radio with a different OM5P-AN
- swapped out the roboRIO
- re-imaged the roboRIO
- reconfigured the radio with the Radio Configuration Utilitiy (16.2)
- checked wifi channels to ensure there was no interference
At one point, we swapped out the OM5P-AN with a D-Link which we reconfigured with the Radio Configuration Utility. The D-Link had much less loss although there was a little. Swapping the OM5P-AN back in produced the same loss as it originally did.
Any thoughts? The driver station laptop is running Windows 7.
Unread 25-01-2016, 21:59
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Radio wifi packet loss
How sound are the connections going from the router too the VRM? Like are all of the wires tinned and soldered, are they just twisted together with electrical tape and bare copper shoved in to the VRM. Even crimped wires aren't the greatest.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 25-01-2016, 22:48
Have you tried a different laptop?
There are two sides to a WiFi connection.
Unread 26-01-2016, 00:27
jweston's Avatar
Rookie Year: 2015
Yes, we did try with another laptop. It actually was worse there. That may have been that laptop. It kept losing track of its network card. The primary laptop has a pretty good track record for wifi but I know that is subject to change.
Forgot to include a snapshot of the loss graph. I hadn't previously got a good look at the volts graph under it (wasn't driving). Interesting. Not sure if it's causative or correlative. Suspicous nonetheless.
Btw, we were not sending commands during most of the time represented by this graph. Sending and receiving does not correlate at all to the drop outs.
Unread 26-01-2016, 00:47
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
In many ways this reminds me of 2015. We had lots of similar problems. Our packet loss sessions came on one minute intervals. At our last event, we quit enabling the USB camera and our problems went away.
Unread 26-01-2016, 00:50
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
I should get a macro for this.
Anyway we had a similar problem where our CAD software had some update thing that would eat our packets alive. Pull up task manager next time you run and see if anything seems out of place.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
Unread 26-01-2016, 00:55
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
If you click on the little gear icon near the chart app, you can pull up a list of all the saved logs. It also displays more attributes than just the ones shown on the DS view.
See if there's another event being logged coinciding with the lost packets.
On the CRIO it was possible to overuse the available ethernet buffers with network traffic, but I doubt something like that is happening on the roborio.
The other thing to check is to see if you are getting network interference from another wifi network in your workspace.
Unread 26-01-2016, 00:59
mdballard's Avatar
mdballard mdballard is offline
SW and Control Systems Mentor
AKA: Matthew Ballard
FRC #4329 (Lutheran Roboteers)
mdballard is an unknown quantity at this point
We have noticed this as well. It didn't seem to depend on relative location between the robot or driver station. Still looking into the issue.
Unread 26-01-2016, 01:21
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
What version of Windows are you running?
Unread 26-01-2016, 07:13
Because this is periodic, I'd open up the task manager, click on Processes and sort by the CPU column. Watch these displays together to see if something doesn't jump up at the same time as the loss starts. This is commonly caused by a SW update or a scan.
Another solution is to leave the laptop on and plugged in overnight and let it finish its background stuff so that it will leave you alone. But I prefer to turn these things off as it will come back to life in the future and cause the same issues.
Greg McKaskle
Unread 26-01-2016, 17:04
jweston's Avatar
Rookie Year: 2015
Thanks for the suggestions! We'll investigate futher. Planning on:
* check the wiring. You know what the electrical team is going to say if we ask if it's solid; of course it is! Ethernet cables and connectors were already checked. They're in great shape.
* watch the process list for CPU usage and other culprits that may be hijacking packets
* try out another laptop
* dig deeper into the DS saved logs
The odd thing is for much of this, the DS should not have been sending or receiving very much data. The camera was disabled.
As for the voltage changes during packet loss, our lead programmer speculates that when the comm fails, the talons are cutting out and back in, causing a change in current draw. That's a plausible explanation but I don't want to assume it's definitely the case. I expect to have more info later tonight.
Unread 26-01-2016, 23:51
jweston's Avatar
Rookie Year: 2015
Results were unsatisfyingly inconclusive. The wiring, while not tinned, is pretty secure so it's unlikely the cause. We used a few more laptops to connect. They had no trouble connecting but all had varying amounts of packet loss. It wasn't consistent. At times, it seemed like if the robot was enabled or disabled, the loss basically went away. It was tempting to say it was the network card except we would go back to a previously used laptop that was having more loss and it was also experiencing little to no loss.
I'm at the point that I'm thinking it has to be environmental. We checked wifi channels. No interference there. The motors and motor controllers are quite close to radio but they remained powered through the lossless comm periods.
We're going to move the robot into another space and try it there tomorrow.
Thank so much for everyone's help.
Unread 28-01-2016, 14:52
Mr.Robby Mr.Robby is offline
Team 4480 Mentor
FRC #4480 (UC-Botics)
Mr.Robby will become famous soon enough
We had experienced this ourself, but again it was brought back to autodesk. We un-installed Autodesk, However still experienced loss. That is because of Akamai Netsession. This program is the Downloader for Autodesk, and is the background downloader causing grief.
Look for it in your add/remove programs. Or if you want to keep autodesk, Akamai has an interface options menu. You can Disable it. That will effectively kill the net connection for Akamai and then you shouldn't experience the loss as well!
Hope this helps!
(Reference thread for Akamai and 4480 http://www.chiefdelphi.com/forums/sh...02#post1531602)
Unread 28-01-2016, 18:28
MrRoboSteve MrRoboSteve is online now
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
If it's at all possible, I recommend using a machine with a clean install of Windows and nothing else as the driver station machine. There are lots of cheap machines out there. Slap a cheap SSD in there, upgrade to Windows 10, and you're golden.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 28-01-2016, 20:58
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
You may be getting a lot of interference on the WiFi band (presumably 2.4Ghz). Try using the inSSIDer utility to map out the WiFi sources around you.
Consider switching to the 5Ghz WiFi band (802.11ac), if your laptop supports that.
Check the bandwidth usage from your laptop using the steps found here.
