Go to Post Every thing is a hammer except for the screw driver which is a chisel. - BradL [more]
Unread 25-01-2016, 22:39
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: 775 Pro Coupling
Thanks for the CAD trick -- I will get one of the students to try it!
An equivalent old-school method uses pitch diameter circles and tangent lines connecting them to calculate the wrap angle on each pulley, and then get center distance from the resulting two arcs and two lines. One such calculator can be found here: http://www.gizmology.net/pulleysbelts.htm
Using that one I got 4.773 inch C-C for a 110 tooth belt connecting a 12 tooth pinion to a 45 tooth pulley at 3mm tooth pitch. Will check that against the CAD result before we cut holes in metal. Measure twice ...
Richard Wallace
since 2003
