Go to Post It's super-ironic that a question about searching was found via searching. Whodathunk? - Brandon Martus [more]
Unread 26-01-2016, 02:20
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: pic: 57's frame is coming along
Originally Posted by Kevin Sevcik View Post
Cooper, that is a fascinating insight. Like I said, this isn't our actual chassis. We're using the aluminum VersaBlocks for the outside wheels on our chassis, but we're using a plastic bearing block for the middle wheel to get the 96 tooth spacing from two simple clamping gearboxes. I'll definitely have the students abuse the chassis a bit to see if we need to do something about the plastic block for the middle wheel. If it's too fragile, I'll have to mill down a versablock to get the same spacing.
I think the block would be fine if it didn't take so much load from wheels being cantilevered. We had the issue on the outer wheels of a wcd and not so much the middle wheel because at that point the middle wheel was in the air, or didn't hit the defense/obstacle first/last.
