Just curious if anyone has gotten GRIP to work on the RoboRIO using a USB camera. We have it running with the Axis IP camera, but the two MS lifecams we tried both throw that same error.
Re: GRIP with USB Camera
GRIP on the roboRIO with our USB Lifecam 3000-HD works without camera error but an old Logitech USB camera from the junk box throws those same errors of a bad couple of bytes in each frame. An Axis M1011 IP camera with GRIP running on the driver station PC runs for about a minute then the image freezes. We might guess the setup of the camera isn't right but the documentation on how to set it up is sparse and there aren't really very many choices to be made anyway.
We are having severe startup problems but if GRIP can make it past the first few seconds after starting on the roboRIO it runs fine albeit a little slow. |
Do I still initialize the camera server when trying to use it with grip? Code:
CameraServer server = CameraServer.getInstance();
server.setQuality(50);
server.startAutomaticCapture("cam1");
If you initialize the cameraserver in your robot program GRIP probably won't be able to access it. Usually only one application can access a camera at a time on Linux.
To get similar functionality as CameraServer, you can use the "Publish Video" operation in GRIP. |
I think we are really close to getting this working!
What is setting property #16? We are getting this error on our deploy: Code:
Jan 27, 2016 1:53:36 AM edu.wpi.grip.core.Main start INFO: Loading file /home/lvuser/project.grip VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP VIDEOIO ERROR: V4L: setting property #16 is not supported Jan 27, 2016 1:53:40 AM edu.wpi.grip.core.Main start INFO: SUCCESS! The project is running in headless mode! |
This is completely harmless. Since we don't do anything to manually configure camera settings in GRIP, any properties that get set are just by OpenCV trying to set up some defaults. Is the project working otherwise? I noticed you have a SUCCESS message and no exceptions. |
#7
Yes! Everything appears to be working. I saw the error an I guess I panicked.
Everything appears to be operational, network tables and all. Should I be concerned about this error? Everything seems to still work but, maybe. Code:
Loading Dependency Injection Framework Jan 28, 2016 3:48:21 AM java.util.logging.LogManager$RootLogger log CONFIG: Configuration done. Jan 28, 2016 3:48:22 AM java.util.logging.LogManager$RootLogger log CONFIG: GRIP Version: 1.1.1 platform: /Linux/arm/ Jan 28, 2016 3:48:28 AM edu.wpi.grip.core.Main start INFO: Loading file /home/lvuser/project.grip VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP VIDEOIO ERROR: V4L: setting property #16 is not supported Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Input must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionEvent SEVERE: Value must have a value to run this step. Jan 28, 2016 3:48:32 AM edu.wpi.grip.core.Main onExceptionClearedEvent INFO: Exception Cleared Event Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main onExceptionClearedEvent INFO: Exception Cleared Event Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main onExceptionClearedEvent INFO: Exception Cleared Event Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main onExceptionClearedEvent INFO: Exception Cleared Event Jan 28, 2016 3:48:33 AM edu.wpi.grip.core.Main start INFO: SUCCESS! The project is running in headless mode! |
#8
While the project is loading, the steps start running before the camera is ready. This isn't really concerning, and it should be fixed in the next release.
#9
Hi Thomas I am still not able to get my camera (Microsoft 3000 USB) to be found in version 1.1.1. Every time I enter 0 the error pops up "A problem occurred trying to start the frame grabber for Webcam 0". I know this camera works do testing it on the robot and on other computers that have the older version of Grip on them.
Sincerely, Joe |
#10
Can you try it on the other computers with a newer GRIP? AFAIK nothing has changed with USB cameras between the last few versions of GRIP, so it may be a driver issue.
#11
Also, we have code that uses the NI camera support to switch the DS feed between multiple USB cameras...but we can't use it if GRIP is running. Is there some way or could a way be added for the robot code to feed images to GRIP instead of GRIP commandeering the camera? We are interested in GRIP but do not want to give up our existing camera server code. |
#12
Figured it out that the drivers of the camera had not been fully downloaded. Thanks for your help.
#13
Hey, so we are having some issues with getting the network tables to work. I was wondering if you guys who got it working could elaborate on how you got that side of things working? We're using C++.
Thanks! |
#14
Hi, all.
My problem is similar to others in the thread, but not quite the same. I can get GRIP 1.2.0 running just fine on my laptop, using the MS Lifecam 3000 USB. it publishes to NetworkTables on the RIO, and then the DS is able to act upon it to control the robot as expected. So far, so good. But when trying to deploy the GRIP to the robot (so it can run headless on the RIO), I get this error: Code:
/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip' Loading Dependency Injection Framework Jun 05, 2015 8:40:12 PM java.util.logging.LogManager$RootLogger log CONFIG: Configuration done. Jun 05, 2015 8:40:12 PM java.util.logging.LogManager$RootLogger log CONFIG: GRIP Version: 1.2.0 platform: /Linux/arm/ Jun 05, 2015 8:40:17 PM edu.wpi.grip.core.Main start INFO: Loading file /home/lvuser/project.grip Jun 05, 2015 8:40:19 PM edu.wpi.grip.core.Main start INFO: SUCCESS! The project is running in headless mode! Jun 05, 2015 8:40:19 PM edu.wpi.grip.core.PipelineRunner$1 startUp INFO: Pipeline Starting OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp, line 3208 VIDEOIO ERROR: V4L/V4L2: VIDIOC_S_CROP Jun 05, 2015 8:40:19 PM edu.wpi.grip.core.Step runPerformIfPossible WARNING: The CV resize operation did not perform correctly. java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method) at edu.wpi.grip.generated.opencv_imgproc.Resize.perform(Resize.java:58) at edu.wpi.grip.core.Operation.perform(Operation.java:61) at edu.wpi.grip.core.Step.runPerformIfPossible(Step.java:139) at edu.wpi.grip.core.PipelineRunner.runPipeline(PipelineRunner.java:196) at edu.wpi.grip.core.PipelineRunner.access$200(PipelineRunner.java:32) at edu.wpi.grip.core.PipelineRunner$1.runOneIteration(PipelineRunner.java:76) at com.google.common.util.concurrent.AbstractScheduledService$ServiceDelegate$Task.run(AbstractScheduledService.java:189) at com.google.common.util.concurrent.Callables$3.run(Callables.java:100) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) I do start GRIP from RobotInit as specified: Code:
/* Run GRIP in a new process */
try {
new ProcessBuilder("/home/lvuser/grip").inheritIO().start();
} catch (IOException e) {
e.printStackTrace();
I also made sure the CameraServer is not running. I'm GUESSING that the camera isn't sending any images to the first pipeline stage (resize)... but there's insufficient debug info in the log to tell me what might be wrong. I checked that the GRIP file is using device 0, and this matches what is in the RIO dashboard (which says "cam0"). Thoughts? -Scott Last edited by s-taylor : 21-02-2016 at 22:19. Reason: fixed <code> tags |
#15
One this I would recommend trying out is the v1.3 release candidate 1. The only thing it changes about cameras is that they now try to restart if they don't work the first time. The problem might be as simple as cameras not connecting the first time because they're initializing or something weird. Let me know if this helps. Last edited by ThomasClark : 21-02-2016 at 23:37. |
