Go to Post I'm not sure why, but I'm getting this picture in my head of a bunch of engineers, huddled in deer blinds with 22's, waiting for the right power wheels toy to drive by. - Tom Line [more]
Unread 26-01-2016, 10:01
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Re: 775 Pro Coupling
Originally Posted by Richard Wallace View Post
-- drill about halfway through #9 (0.196 inch dia) <-- [size="2"][b][i]this step gives a press fit hole diameter for the 5 mm motor shaft
We're looking at how to get a 19t 32dp pinion onto our 775Pro shafts for our shooter. My students effectively designed a clone to the AndyMark Cim-Sim, stealing the shaft, cluster gear, and bearings and using a 19t gear from bane bots that was thought to be appropriate. Long story short, that gear has a 5mm bore, but is also 40dp (we think). As of right now the plan is to modify 19t 32dp gears from AM to fit the 775Pro.
My dilemma this morning was related to fixturing the gear, but also whether to use a #10 drill then ream the bore to .1955" or .1960". This gives you either .0007" or .0012" interference. At this size a proper press fit is .0002" to .0014" interference. If I don't have to spend $40 on tooling it wouldn't hurt my feelings though. My only concern is that a slipping pinion might be pretty difficult to diagnose and could be a pretty severe failure mode in a competition environment.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
